Temperature reading not working
30 Nov 2012 19:08 #3462 by dado099
Temperature reading not working was created by dado099
first of all congratulations for v2 software, it's fantastic, it has everything you can need.
then a simple question:
I just upgraded devo6s with v2.0 but I have a little problem:
with 2 rxes, minicp and v120d02snew, having both temp sensors connected,
the temperature displays "----" while rx voltage is corretly displayed.
With original fw it worked correctly.
Any help ?
Thanks again.
01 Dec 2012 01:39 #3477 by suvsuv
Replied by suvsuv on topic Temperature reading not working
Try upgrade with attached dfu, it should work.
Note that in this latest version, telemetry is turned off by default, you need to turn it on in the model setup page by pressing the Devo button
01 Dec 2012 06:43 - 01 Dec 2012 07:15 #3485 by vlad_vy
Replied by vlad_vy on topic Temperature reading not working
With WK-CTL01-D telemetry module:
1) Only T2 sensor working. T1, T3, T4 sensors not working. Over time they show some values, even if they disconnected.
2) Volt1, Volt2 and Volt3 sensors working.
3) RPM1 and RPM2 working
4) GPS working
It is the same for all releases begin v2.0.0. Something wrong with temperature sensors.
Last edit: 01 Dec 2012 07:15 by vlad_vy.
01 Dec 2012 08:47 #3486 by dado099
Replied by dado099 on topic Temperature reading not working
suvsuv wrote: Try upgrade with attached dfu, it should work.
Thank you, but I have devo 6, the file attached seems to be for devo 8.
01 Dec 2012 11:43 #3488 by suvsuv
Then try this one instead
01 Dec 2012 14:17 #3496 by dado099
suvsuv wrote: Then try this one instead
Thank you suvsuv, I've just tried, but it doesn't work either.
The curious thing is that if I set a low alarm value on Temp1 it works correctly (beeps) and correctly stops beeping if I unplug the sensor.
So it seems it reads correctly, but no display ! :blink:
03 Dec 2012 16:44 #3580 by PhracturedBlue
Replied by PhracturedBlue on topic Temperature reading not working
should be fixed in the current code. the problem was a typo where we only displayed one temp in all 4 slots and if that one wasn't enabled you got '---'
Time to create page: 0.313 seconds
