- PPM issues (Was: It's time for a 2.1 release?)
11 Dec 2012 11:55 - 11 Dec 2012 11:56 #3872
Replied by vlad_vy on topic It's time for a 2.1 release?
Maybe more safe will be to have 2 subset of PPM, standard 8 channel PPM-OUT (for outer modules) and PPM-SIM? Without PPM config options.
Last edit: 11 Dec 2012 11:56 by vlad_vy.
11 Dec 2012 13:29 #3873
Replied by PhracturedBlue on topic It's time for a 2.1 release?
Nah. The defaults should be fine for everyone using a Sim (especially since you need to calibrate in a sim anyway). Only in the case you need an external module may you need to tweak the values.
- domcars0
11 Dec 2012 13:50 #3874
by domcars0
I've just tested my Devo 10/Deviation (release of last saturday #a8d0315) as trainer on my WK2801 (as master) ...It works, I've just to trims the zero of all channels which are away from the good value.
Replied by domcars0 on topic It's time for a 2.1 release?
Or if you use your deviation Tx as trainer on another radioPhracturedBlue wrote: Only in the case you need an external module may you need to tweak the values.
12 Dec 2012 15:29 #3922
Data pulses for different radios
github.com/blutack/paparazzi/tree/v3.9/conf/radios
- suvsuv
13 Dec 2012 02:12 #3966
by suvsuv
As different TX vendors use different setting for PPM output, e.g. Futaba's PPM settings are notch=300us and center+notch=1.5ms, there is no actual PPM standard. I might let the Frame pulse width be configurable between 20000 and 22500m
Replied by suvsuv on topic It's time for a 2.1 release?
Now PPM output can be tweaked for different PPM-FM module, below is test result to generate PPM complied with walkera's TXPhracturedBlue wrote: I implemented a config option in the code.
the default is set to match the devo10's normal output.
I also added support for more than 10 channels, though I'm notsure it will actually work.
Let me know if you have further issues. It works fine in Phoenix
13 Dec 2012 04:25 #3971
I thought about that, but so far everything has worked fine with the 22.5ms frame rate. should we need to change it in the future it is easy to add.
16 Dec 2012 07:49 #4027
PPM frames may be fully specified by:
- Max Frame-Rate: 25Hz - 100Hz (typical 50Hz) => Min-Frame-Width: 40ms-10ms (typical 20ms)
- Min Frame-Sync: 2.0ms - 5.0ms (typical 2.5ms)
- Channel-Separator: 200us - 500us (typical 400ms)
- Channel-Polarity: +/- (typical +)
16 Dec 2012 13:37 #4038
I think I'll wait until after 2.1 to modify this. I've fronzen all string changes for the release, and I don't think this is worth waiting for all strings to get synced again.
Time to create page: 0.050 seconds
