- DEVO7E move toggle icons around the screen ?
- blackmoon
31 Jul 2013 19:38 #12659
by blackmoon
DEVO7E move toggle icons around the screen ? was created by blackmoon
I'm curious how you move the toggle icons around on a devo7E or 10 btw.
Not that I really need an icon to tell me the switch position, but since they are available I tried to configure a TH toggle.
Issue is, it's in the middle of the screen right on top of my trim bars.
I'm using deviation-devo7e-v3.0.0-ddf6350 nightly.
Thanks.
Thanks.
31 Jul 2013 19:45 #12660
Replied by FDR on topic DEVO7E move toggle icons around the screen ?
From the main page config you open the layout with a long ENT press, then one item will be selected which you can move with the left/right/up/down buttons. "Move" is written in the upper right corner when you can move an element.
After positioning it press EXT, now you can tab throw the elements and select the next one you want to move. Then press ENT, and you are in move mode again...
- blackmoon
31 Jul 2013 19:48 #12662
by blackmoon
Replied by blackmoon on topic DEVO7E move toggle icons around the screen ?
long ENT doesn't work... no way to get to the layout.
31 Jul 2013 19:53 #12664
Sorry to hear that.
I don't have a DEVO 10, I just tried it in the emulator...
- blackmoon
31 Jul 2013 20:00 - 31 Jul 2013 20:01 #12666
by blackmoon
It's on the nightly build DEVO 7E.
It doesn't show the "press long ENT for preview" message at the top either.
My DEVO 10 has the vanilla 3.0 build and the long ENT preview is working.
Anyway I'll try a more recent nightly, mine is from 19/07 and see if it's fixed.
If not, I'll file a ticket.
Last edit: 31 Jul 2013 20:01 by blackmoon.
Time to create page: 0.082 seconds
