Tx-Power
11 Aug 2013 11:10 #12902 by offspringfan
Tx-Power was created by offspringfan
just got my new Super CP with Devo 7e!
Deviation runs fine except that i cant reduce the transmitpower. There is only one option availible (150mW), but in germany this is not legal and in my opinion also too much for flying in my garden.
Is there a way to reduce the outputpower?
Thanks in advance,
Andi
If it is important, i use Deviation v3.0 with the two switches mod and a WLToys transmitter module.
11 Aug 2013 12:17 #12903 by dehalo
Replied by dehalo on topic Tx-Power
Did you do the diode mod?
If yes you should edit tx.ini:
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
then you should get all power options.
If not, you will have ~7 mW, whatever deviation says.
11 Aug 2013 12:24 #12904 by offspringfan
Replied by offspringfan on topic Tx-Power
Thank you.
Then i guess the next thing to do is the diode mod :cheer:
I was just wondering because with the V911 i was able to chenge the outputpower.
11 Aug 2013 14:00 #12905 by PhracturedBlue
Replied by PhracturedBlue on topic Tx-Power
Before you do the mod, If you haven't done it, the actual power is 10mW regardless of what Deviation says.
On a stock Devo7e, the max available power is 10mW. Deviation says 150mW because it is sharing the same code as the devo10. On the devo10 with the same settings, the output is 150mW, but the Devo7e has no power-amp, and thus these same settings only provide 10mW
14 Aug 2013 22:22 #12981 by jason4207
Replied by jason4207 on topic Tx-Power
V911 uses a different radio (A7105) with it's own built-in power amp. It doesn't use the the stock radio (CYRF).
If you install a A7105 radio module w/ a built-in power amp then you are not artificially restricted like you are on the stock radio module when using the A7105 radio.
Each radio module is a completely different entity w/ or w/o their own power amp. ;)
Time to create page: 0.093 seconds
