- I deleted devo 7e Bootloader. But now working...
- SadSack
12 Sep 2013 23:52 - 16 Sep 2013 10:35 #13748
by SadSack
I deleted devo 7e Bootloader. But now working... was created by SadSack
Hi
Well I've been very silly(not the word i want to use) While i was poking around Devo7e using StLink v2. I thought i was just looking But! was making changes, Flash is now unprotected...whoops
Now Walkera's DFU loader does have CRC checking but ST Loader does good job too. Well not going to find Walkera's loader anywhere and ST's i just can not find it anywhere, maybe just not using right wording in my search.
I've looked though forum and i can find info about bootloader but nothing on how to go about replacing it or even files needed.
Any help would be great
Last edit: 16 Sep 2013 10:35 by SadSack. Reason: Now working
13 Sep 2013 04:14 - 13 Sep 2013 04:14 #13754
Replied by FDR on topic I deleted devo 7e Bootloader. So its dead...
Send PhracturedBlue a PM.
I don't know if he has the bootloader for the 7E too (he had for the 8 ), but he can extract it from his...
Last edit: 13 Sep 2013 04:14 by FDR.
- SadSack
13 Sep 2013 10:46 #13757
by SadSack
Replied by SadSack on topic I deleted devo 7e Bootloader. So its dead...
Thanks. I'll do that and hope
- SadSack
13 Sep 2013 16:17 #13763
by SadSack
Pm sent.
Now I have STlink can i manually flash and run code, if so how ?
- SadSack
14 Sep 2013 04:45 #13768
by SadSack
Well St bootloader is intact and quit easy to get running but no luck as yet re-flashing Devo7e.bin.
Anyone got other info ?
14 Sep 2013 05:07 #13769
The ST bootloader won't do, because the fw in the dfu is slightly encoded, and the bootloader will decode it, but only the Walkera bootloader will do it, the ST do not...
- SadSack
14 Sep 2013 06:22 #13771
by SadSack
ahh! that would be why then
So compiling without offset not going to be very easy...doh
14 Sep 2013 06:26 - 14 Sep 2013 06:35 #13772
Actually, you can try to remove the encoding from the python script, which makes the dfu...
Last edit: 14 Sep 2013 06:35 by FDR.
- SadSack
14 Sep 2013 06:39 #13773
by SadSack
i just renamed dfu.py so it couldn't be used.
Bin file still looks the same ...bugger
14 Sep 2013 06:45 #13774
I think the bin file is fine and should be the same. It is only encoded during packing it into the dfu...
So if you can upload the bin to the appropriate address, it might work...
- SadSack
14 Sep 2013 07:31 #13775
by SadSack
used address 0x08000000 and 0x08003000 and no joy.
Far to many options and I'm only guessing
So many pieces to the puzzle....
- SadSack
16 Sep 2013 10:38 #13822
by SadSack
Replied by SadSack on topic I deleted devo 7e Bootloader. But now working...
Well I got lucky and change 'option bytes' and it running again!! No walkera loader so have to open tx to do updates but does free up 12k, so not all bad.
- RandMental
16 Sep 2013 11:53 #13825
by RandMental
Replied by RandMental on topic I deleted devo 7e Bootloader. But now working...
Might be useful to the forum if you explain how you did it and where to make the connections.
- SadSack
16 Sep 2013 12:32 #13826
by SadSack
I can do that. I used STLinkv2 but using usb/serial should do it as well.
I'll do some screen grabs. Mostly because I don't understand the options I used and someone with greater understanding could complete the picture with little more info.
- domcars0
16 Sep 2013 19:10 #13832
by domcars0
Replied by domcars0 on topic I deleted devo 7e Bootloader. But now working...
+1 !RandMental wrote: Might be useful to the forum if you explain how you did it and where to make the connections.
- SadSack
17 Sep 2013 15:01 #13861
by SadSack
Yes I shall do write up on updating TX without Walkera loader, using STlinkv2 and ST serial bootloader. Results are little odd but all appears to work OK.
Well i have a Q: about how to compile Deviation Nightly Builds ?
I made minor change to make file so i could compile using 'make target=devo7e' which works fine, no problems there.
Still to re-flash using ST's serial bootloader i need Bin file that i 128k in size and loads @ 0x08000000. Though code needed to run start's @ 0x08003000.
Using STlink I can use Bin file that make spits out but using ST serial bootloader I have to use a full 128k bin otherwise it don't work.
Can make file be simply changes to do this?
Time to create page: 0.270 seconds
