compatibility between TX DEVO 8S and RX-2618v
17 Oct 2013 10:26 #14719 by Casa
i need your help please...
i have a rx-2806 and a rx-2618v and i use Tx wk-2602.
I'm thinking to buy the new TX DEVO 8S but i wouldn't replace my old rx!
So the question is....Are the rx-2806 and rx-2618v compatible with the DEVO 8S
transmittent??
best regards
Andrea
  • rbe2012
  • rbe2012's Avatar
17 Oct 2013 12:35 - 17 Oct 2013 15:27 #14720 by rbe2012
Replied by rbe2012 on topic compatibility between TX DEVO 8S and RX-2618v
Both receivers are for the old Walkera protocol (WK260x, the six-channel- transmitters).
They are not compatible to the Devo8 with stock firmware (as this transmitter uses the new Devo protocol).
If you install our replacement firmware deviation on your new Devo8(s), you can control the new Devo receivers as well as the older Walkera receivers (and many more, see on the Home site).
Last edit: 17 Oct 2013 15:27 by rbe2012.
17 Oct 2013 14:22 #14724 by Hexperience
Replied by Hexperience on topic compatibility between TX DEVO 8S and RX-2618v
I fly my 2702v on 2801 protocol. Works fine.
20 Oct 2013 14:29 #14808 by Casa
thanks very much for your suggestions....
so when i'll buy devo 8s i upgrade it with new firmware!!
Time to create page: 0.080 seconds
