Toggles to display channel value
- yidc
03 Jan 2014 02:44 #17802
by yidc
Toggles to display channel value was created by yidc
In "Main Page Config", toggles can be used to display switch value e.g. HOLD/FMOD/MIX/GEAR
can it be used to display channel value as well? e.g. virtual channel used for trim button (-100/+100) which I think perfectly acting like a switch
I tried but I cannot select toggle icon for "1"
03 Jan 2014 03:55 #17806
Replied by PhracturedBlue on topic Toggles to display channel value
I'm not sure what you mean by not being able to set the icon, but if you set the input to 'virt1', the toggle will show when the value is > 0
- yidc
03 Jan 2014 04:17 #17809
by yidc
Replied by yidc on topic Toggles to display channel value
PB,
You may take a look at the screen shot.
When I choose a channel as the input of toggle (Virt3 for my case), press "DN" cannot go down to let me choose icon for "1", while press "UP" will make the underline of "0" also disappear too
As a workaround, I need to first choose any switch (e.g. FMODE) as input, choose icons for "0" and "1", then change to my desired channel later
03 Jan 2014 05:44 #17813
Thanks for explaining. That is a bug on the Devo7e/10 only. I have fixed it and it will be in tomorrow's nightly as well as the 4.0.1 patch I'll be making.
- yidc
03 Jan 2014 05:56 #17815
by yidc
Noted with lots of thanks!! =)
Time to create page: 0.144 seconds
- Toggles to display channel value
