- Devo 8S with MultiMod: NRF based Protocol issue
- btoschi
23 Apr 2014 22:27 #22676
by btoschi
Devo 8S with MultiMod: NRF based Protocol issue was created by btoschi
I've build a multi module with A7105 and nRF Chip (no PA Versions for now) and modded my Devo 8S with it.
Deviation is custom build from source (trying MJX/UDI protocols), A7105 (Hubsan protocol) is working fine.
But my V272 and SanHuan copters (YD protocol) behave *strange*: They bind fine, but whenever it comes to controlling it, it seems to send wrong / outdated commands, throttle down happens with heavy delay.
I've let my SLH 6047 "Scorpion" Tricopter scratch the ceiling for some seconds due to that (and I initially believed it was due to protocol differences), but my new V272 behaves exactly the same. Upgraded V959 (V222 board) is also not really controllable.
Using Stock transmitters all is working fine.
I suspect something is wrong with Switch or NRF board (though I've used that before on my arduino projects).
Any clues where to start to search ?
24 Apr 2014 01:22 #22678
Replied by hexfet on topic Devo 8S with MultiMod: NRF based Protocol issue
Can you try a directly connected nRF module, so the multi-module can be ruled out as a possible issue?
With the V222 board and V272 you're using the V202 protocol? If so I'd think the first suspect is reading data from the nRF module - check the MISO connection.
If the problem is only with YD717 protocol I'd first check for a protocol difference. Maybe the SanHuan expects a checksum, which randomly matches so only it only responds to a small percentage of received YD717 packets (which have no checksum). Have you tried the SkyWalker protocol option in YD717?
- btoschi
25 Apr 2014 19:55 - 25 Apr 2014 19:55 #22722
by btoschi
Replied by btoschi on topic Devo 8S with MultiMod: NRF based Protocol issue
I'll check with directly connected module later (Better check cables twice then ^^). Anyway, the A7105 based protocols are working fine.
Yes, using V2x2 protocol for V222 and V272.
I have sniffed some more data (finally got simple Saleae SDK based real-time SPI (+Radio Enable) output working) of San Huan, its definately the same like YD-717 besides some minor differences in bind packets - which don't matter, it seems. Also tried Sky Walker option, without any difference in (mis-)behavior.
The idea with MISO sounds reasonable - V2x2 and YD717 protocol both check for packet send / timeout conditions, thus need to read proper data back.
Is there a way to perform live-log viewing / stderr redirection / debugging on Devo via USB cable (Linux solutions preferred
) ? I've seen the comment on dbgprintf in Deviation YD717 sourcecode ...
Last edit: 25 Apr 2014 19:55 by btoschi.
- victzh
25 Apr 2014 22:10 #22723
by victzh
Replied by victzh on topic Devo 8S with MultiMod: NRF based Protocol issue
To enable printf to UART (trainer port) 115200bps,8,n,1 :
make TARGET=devo8 TYPE=dev
- bampi2k
01 May 2014 03:23 #22817
by bampi2k
Replied by bampi2k on topic Devo 8S with MultiMod: NRF based Protocol issue
Don't know if it is relevant here. But I am getting similar situation problems with the v272 using the v2x2 protocol. I am using the devo 7e without any multi module interface. Just the nrf module added directly. It binds fine... Can hover... But starts drifting like crazy to the left after a few seconds or I after I give some big stick inputs. The throttle also seems to get stuck at the times!!!... Could it be a setting issue??
- victzh
01 May 2014 16:01 #22833
by victzh
May be you have a defective board? Or motors? Do you have an original TX or another V2x2 model to compare the behavior? As long as it binds and Deviation does not freeze or reload by itself (it can happen if the contact between nRF module and the main board weakens) I doubt it is a transmitter problem.
bampi2k wrote: Don't know if it is relevant here. But I am getting similar situation problems with the v272 using the v2x2 protocol. I am using the devo 7e without any multi module interface. Just the nrf module added directly. It binds fine... Can hover... But starts drifting like crazy to the left after a few seconds or I after I give some big stick inputs. The throttle also seems to get stuck at the times!!!... Could it be a setting issue??
- bampi2k
04 May 2014 03:14 #22868
by bampi2k
Thanks for the reply, i dont have another v2x2 to compare!
I dont even have the original TX!
I will try to find a buddy with the original TX.
The TX is absolutely fine. I can bind fine. Never freezes or anything ODD!
Just wondering, what could be the problem with the board/motors, could i try and troubleshoot!? am feeling adventurous!
- victzh
05 May 2014 06:11 #22900
by victzh
What you describe seems to be a problem with gyro - because of motor vibration gyro can drift away thus signaling wrong position to navigation software. As the design of the heli is more or less monolithic, they usually take measures in software. May be you have extremely vibrating propellers. Balancing propellers and removing vibration to the board should help.
But to exclude transmitter issues I would try to borrow a transmitter from a friend, if possible.
- bampi2k
05 May 2014 07:24 #22904
by bampi2k
No vibrations in the motor or the propellers. I am searching for a tx From someone. In the meanwhile customer service has agreed to ship a replacement quad. I have told them to check thoroughly before shipping.
Time to create page: 0.067 seconds
