Devo 7e pitch curve
04 Jan 2015 10:17 #27458 by Iroquois
Devo 7e pitch curve was created by Iroquois
I have a Devo 7e with Deviation Firmware. Can anyone tell me how to set up the pitch curve for a 140 degree swashplate system (Walkera 'Super CP').
04 Jan 2015 11:40 #27461 by jesmail
Replied by jesmail on topic Devo 7e pitch curve
Go to the models section, there you will find working models for the Super CP from beginner to 3D advanced. You can use or learn from them to make your own.
04 Jan 2015 14:29 #27466 by FDR
Replied by FDR on topic Devo 7e pitch curve
Super CP nedds the 1 servo (normal) splash setting, which is the default.
You can setup the pitch curve on channel 6.
04 Jan 2015 22:40 #27494 by Iroquois
Replied by Iroquois on topic Devo 7e pitch curve
Thanks for that. It looks like I may take some time to work through the available info.
08 Feb 2015 01:50 #28444 by marky_mark
Replied by marky_mark on topic Devo 7e pitch curve
Surely the Super CP is a Normal not 140 deg swash!
Time to create page: 0.096 seconds
