- Devo 7e Orange open LRS long distance 8km
- Del
02 May 2015 08:07 #31924
by Del
Devo 7e Orange open LRS long distance 8km was created by Del
It would be very interesting to weld this module to our devo 7e and create the protocol to work.
It's great for FPV long distancie
I hope that with everyone's help we can make a tutorial.
Transmiter
Receiver
Url articules :
www.hobbyking.com/hobbyking/store/__4003...strSearch=Open%20lrs
www.hobbyking.com/hobbyking/store/__2709...trSearch=Orange%20lr
www.hobbyking.com/hobbyking/store/__2709...strSearch=Open%20lrs
Transmiter
Receiver
Url articules :
- Arakon
02 May 2015 12:46 - 02 May 2015 12:47 #31937
by Arakon
Replied by Arakon on topic Devo 7e Orange open LRS long distance 8km
It's a PPM module. You can just hook it up via PPM, no need for any protocol work.
On a side note, 8km is highly.. optimistic.
Last edit: 02 May 2015 12:47 by Arakon.
- Del
04 May 2015 09:24 #32054
by Del
Replied by Del on topic Devo 7e Orange open LRS long distance 8km
First thanks for your help.
Connect by Jack ppm is the cable?
Could you tell me where I have to solder the wires of the module orange?
what hobiking article I have to buy Futaba or JR or Turnigy compatible?
forgive my bad translation does not speak good English
Thank
Thank
- Del
- Del
04 May 2015 16:48 #32072
by Del
How to put this working ?
- Deal57
04 May 2015 18:15 #32073
by Deal57
Replied by Deal57 on topic Devo 7e Orange open LRS long distance 8km
Where your screen now says <*Flysky*> use the right button R+ to scroll to the PPM protocol. Section 8 of the users Manual has a detailed description.
- Del
04 May 2015 19:34 #32078
by Del
Ok PPM
PP In : None , Channel or Stick ?
- Deal57
04 May 2015 19:55 #32079
by Deal57
None, I believe. Page 23 describes how it is up used and it doesn't seem to apply here.
- kungpow
04 May 2015 20:06 - 04 May 2015 20:08 #32080
by kungpow
Replied by kungpow on topic Devo 7e Orange open LRS long distance 8km
ppm in won't and can't be used because you're using ppm out ppm in is for buddy boxing or a head tracker.
On a side note does anybody know if there is a reason that openlrsng hasn't been implemented in deviation using a SI4332 module? All the protocol work is open source so it seems like it would be easy.
It would offer easy multiple miles of range and telemetry which is something the ppm module can't do so I can't see people not wanting it.
Last edit: 04 May 2015 20:08 by kungpow.
- Del
04 May 2015 21:38 #32085
by Del
I found this video , to convert LRS module orange ppm orege
- Del
15 May 2015 12:32 #32616
by Del
Como puedo flashear y programar el tx y rx para su maximo alcance ?
As I can flash and set the tx and rx for maximum range?
Time to create page: 0.178 seconds
