fixed id
02 Jun 2015 19:14 #33369 by mart123
fixed id was created by mart123
am I overlooking something? but how the hell do you turn fixed id off in the devo 10 with firmware 4 on?
I cant bind with the rx that came with it the rx1002
03 Jun 2015 00:02 #33373 by mwm
Replied by mwm on topic fixed id
It's in the model setup. Just set the Bind ID to no string.
You may also need to clear the binding on the rx1002. Don't have one, but the Walkera Rx's I do have have to have to have the binding cleared before they'll bind to anything.
03 Jun 2015 08:53 #33384 by mart123
Replied by mart123 on topic fixed id
hi mvm, I sorted it, I didn't realise I could turn fixed id off unless the receiver was powered up..doh
I now have another problem of trying to assign a switch for the 3 flight modes I set up in the brain unit...(
advice or a code I can drop in would be apreiciated.. ;)
regards mart
03 Jun 2015 12:39 #33392 by mwm
Read my model config tutorial . That walks you through setting up my Blade 200QX config, including multiple ways to set up flight mode switches. It uses the advanced GUI, but I believe you'll have to use that to set up flight modes anyway.
The easy way to do switches for flight odes is to have a mix on the flight mode channel, one mixer per flight mode. Each mixer uses the switch setting you want to turn on that flight mode, a fixed curve with scale set to the output value for that flight mode. And they are all replace.
04 Jun 2015 13:35 #33417 by mart123
cheers mwm and thanks for taking the time to reply.
mart
Time to create page: 0.222 seconds
