- Solved : That 7E bind drives me crazy !!!
- Thie
02 Jun 2015 21:44 - 03 Jun 2015 17:43 #33370
by Thie
Solved : That 7E bind drives me crazy !!! was created by Thie
I'm happy to be able to write here. I'm trying to create my account for a while. But the confirmation mail was kept by my provider...
So. Hi all !
Sorry to have to ask your help for such a basic problem, but I'm driving crazy.
I've fit (carefully) a XL7105-D03B module on my Devo 7E.
Updated with the 4.01 of course, modified the tx.ini file (A13 + PA) with notepad++
And it's impossible to bind it neither with a flysky receiver (FSR6B or FSGR3E) nor HK GT2R
I've checked the wiring many times.
I've activated the module in the TX.INI file, erased the semicolumns ;
Tried to activate/deactivate the power amp
Tried to activate/deactivate "has_pa-cyrf6936=0" and =1
Tried to modify the mode in the tx.ini file and it has been modified on the radio too...
I've tried to bind with and without the ID too....
Tried to connect by the old way ((8 to GND and 9 to 3.3V) and the new one (6 to 9 and 7 to
Tried to connect the ground on the pcb or on the other module as seen on a post.
Read a lot of post...
Format, reflash, recopy etc....
I can't bind.
The second strange thing is that there's always a little noise in the buzzer since the upgrade.
I've unplugged it and activated the shaker (vibration).
So, please, the sound is not a problem, but what can I do to fix it ? This is the last step to be able to try my last new home made model ?????
So. Hi all !
I can't bind.
Last edit: 03 Jun 2015 17:43 by Thie.
- Arakon
03 Jun 2015 04:22 #33380
by Arakon
Replied by Arakon on topic That 7E bind drives me crazy !!!
Try updating to the latest nightly. Since 4.0.1, a few hundred changes and fixes have happened.
Just watch out, the module settings move to hardware.ini in the nightlies.
Does the module show as installed? i.e. no * in front of the protocol name?
- Thie
- Thie
03 Jun 2015 10:53 - 03 Jun 2015 10:58 #33388
by Thie
Replied by Thie on topic That 7E bind drives me crazy !!!
Last edit: 03 Jun 2015 10:58 by Thie.
- Thie
03 Jun 2015 17:35 - 03 Jun 2015 17:45 #33398
by Thie
Replied by Thie on topic The Soluce
Thanks to MWM on an other forum, I've commented out and disabled the CYRF and its PA (with =0) in the hardware.ini file.
I could find the "flysky" option in /model menu/model setup/ and that has binded at the first try !
I hope that will help someone.
Happy now
I forget : Thank you to all of you that developed DeviationTX, this project is awesome
Happy now
Last edit: 03 Jun 2015 17:45 by Thie.
Time to create page: 0.117 seconds
