Supported Models ? - NiHui U807 and Eachine H8C
25 Dec 2015 00:33 #41127 by misherman
New member. I want to fly several models with a better transmitter, so I am looking at Devo 7e and 10 with deviation software.
1) Checking to make sure my models are included and see that in the "Supported Models" link to the RC Model database the U807 is supported for the Flysky protocol using Module A7015 (line 95). All the other models designated for Flysky indicate the Module as A7105. Can someone confirm that this is just a typo and not a one-off module?
2) Same question for the Eachine H8C (line 19). This is the only place where the module is designated NRF24K01. All others are NRF24L01. Typo?
3) If I need both the A7105 and NRF24L01 does the Devo 10 offer any advantage over the 7e by supporting more protocols that don't need to be soldered in?
Appreciate any response.
25 Dec 2015 21:27 #41137 by gdenton
1 & 2 = typos.
3: Advantages of the 10 over the 7E:
The mod required on the 7E to get full power for Devo and Spectrum protocols is not the easiest thing to do.
The 10 has more switches and pots which you would have to add to the 7E if you need them.
I have a 7E and a 10, after I got my 7E modded I hardly ever use the 10 anymore, I like the size/weight of the 7E much better.
I also recently purchased a 6S, already has two 3-way switches and no power mod required.
25 Dec 2015 22:18 #41139 by misherman
Replied by misherman on topic Supported Models ? - NiHui U807 and Eachine H8C
Thanks, just what I needed to hear. Looks like I'll be sending $63 to Banggood (pretty good deal for US warehouse).
25 Dec 2015 22:26 #41140 by gdenton
I assume you're talking about the 7E, $50.82 on Ebay, shipped from California:
www.ebay.com/itm/Walkera-DEVO-7E-2-4G-7C...c:g:fLMAAOSwQPlV-25c
26 Dec 2015 01:59 #41143 by misherman
Yes, much better. I was confusing the Hubsan X4 107d BNF from banggood for $63 www.banggood.com/Hubsan-H107D-FPV-X4-5_8...er-BNF-p-910310.html , which will be my first FPV quad and the reason I want the Devo.
So many items on the wish list - devo, quanum v2, vdq210, ml210,...!
Thanks, again.
Time to create page: 0.292 seconds
