PPM Input, Buddy Box Problem, PPM5 not working
17 Feb 2016 18:46 - 17 Feb 2016 21:43 #43208 by mario123
I'm building myself a buddybox transmitter, which is only sending out a PPM signal. It works so far. I can control my channels, so my basic connection works, I guess. I'm transmitting 8 channels.
My problem is if I take an virtual channel and select as source the PPM5, there is no signal coming on the mixer page. It doesn't matter if the trainer switch is flipped or not.
If this channel is routed through the option in the model settings(when I click on stick), it's working. With the trainer switch flipped.
The reason I'm doing this is, because the instructor might have the selfbuilt transmitter and he should have the control over the trainer switch.
Anyone got a tip for me?
Btw I'm using deviation v4.0.1 on a Devo 10 without additional modules
Greetings from Germany
Mario
Last edit: 17 Feb 2016 21:43 by mario123.
24 Feb 2016 06:32 #43545 by mario123
Replied by mario123 on topic PPM Input, Buddy Box Problem, PPM5 not working
Nobody got a tip for me? :(
24 Feb 2016 07:38 #43546 by mwm
Did you set the PPM options to 5 channels of input? It defaults to only 4.
24 Feb 2016 12:09 #43550 by mario123
My third try to reply.
Thank you for your answer!
Yes all the ppm inputs are assigned to an unused switch. The value of the switch change if the ppm signal is varied.
But in the mixer page there's no movement in the graph, no matter which ppm input I select.
24 Feb 2016 23:53 #43592 by mwm
Please post your model file, and tell us which version of deviation you are running (the complete string displayed on boot or the about page).
25 Feb 2016 06:17 #43600 by mario123
Im going to post the model.ini later.
The string in the display is devo10-v4.0.1
This is the newest stable, isn't it?
25 Feb 2016 06:51 #43602 by mwm
That is the newest release, but it's now over two years old. I believe you're encountering a bug that's long since been fixed in the nightlies. If you haven't installed extra hardware, you might try installing the latest nightly and check on it. It has many fixes and improvements, including showing virtual channels in the channel monitor so you don't have to rely on the mixer display to see if they are working properly.
25 Feb 2016 16:42 #43625 by mario123
Here's my model.ini
I haven't upgraded yet because I thought it might get unstable. ("Never change a running system") I haven't installed any additional modules yet but i might inastell an an nrf24 in a few weeks.
25 Feb 2016 17:37 - 25 Feb 2016 17:41 #43634 by Cereal_Killer
Replied by Cereal_Killer on topic PPM Input, Buddy Box Problem, PPM5 not working
mario123 wrote: ...I haven't installed any additional modules yet but i might inastell an an nrf24 in a few weeks.
He only mentioned it cause there's a wiring change from the old 4.0.1 to the nightly builds is all. If you're doing a new install there's no concern as you can just wire it all up the new way and flash it then.
mario123 wrote: I haven't upgraded yet because I thought it might get unstable. ("Never change a running system")
As mentioned; you've found a bug, therefore your system isn't currently running right so no need to "not mess with a WORKING system". Fire up the computer, it's time to update that bad boy!
Last edit: 25 Feb 2016 17:41 by Cereal_Killer.
27 Feb 2016 18:14 #43779 by mario123
Update:
I have upgraded to the newest nightly.
There are some nice new options!
But its still not working. I'm using the same model.INI. I have done an instructor/student flight everything worked good. So my basic Ppm connection is working. But if I set the source of an virtual channel to Ppm 5 or any other. The graph shows no movement. Even though the channels are verified to work in an instructor/student mode.
Time to create page: 0.106 seconds
