- Stock CYRF6936 power at 150mW in Devo 7E?
- saidem
25 Mar 2016 16:28 - 25 Mar 2016 16:37 #45159
by saidem
Replied by saidem on topic Stock CYRF6936 power at 150mW in Devo 7E?
Do you think that this module has the same functions as the original?
Strange, he has no shield to.
Thanks for your help.
www.aliexpress.com/item/2-4-G-module-CYR...ule/32613374852.html
Last edit: 25 Mar 2016 16:37 by saidem.
- victzh
25 Mar 2016 16:34 #45161
by victzh
Replied by victzh on topic Stock CYRF6936 power at 150mW in Devo 7E?
It does not have Power Amplifier, so it's short range only.
- saidem
25 Mar 2016 17:47 #45168
by saidem
And this one what do you think?
www.aliexpress.com/item/2-4-G-module-CYR...6f-bc63-9eea0a5afb63
- victzh
25 Mar 2016 18:37 #45169
by victzh
This one is even listed in "official" Deviation Module List, albeit under different name:
www.buychina.com/items/2-4g-module-cyrf6...m-module-uuruunslkhi
It has PA and described here: bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList
- saidem
25 Mar 2016 19:21 #45175
by saidem
Thank you, fine, I had completely forgotten this Deviation folder. But without shield, it will not cause interference?
- czajunia
07 Apr 2016 15:45 #46037
by czajunia
Replied by czajunia on topic Stock CYRF6936 power at 150mW in Devo 7E?
I have replaced my stock CYRF module with the one for Devo 8/12.
I was wondering is there a way to enable different TX power settings in the menu the same way they are available for other modules? For DSM2/DSMX/Devo protocols I only have "default" option available which is the max 150mW setting I presume.
Thanks.
Thanks.
- victzh
07 Apr 2016 18:16 #46045
by victzh
Yes, check hardware.ini file on your Devo - it has a commented out line
; has_pa-cyrf6936 = 1
Remove semicolon in the beginning of this line and you're good to go.
07 Apr 2016 18:37 #46051
Replied by mwm on topic Stock CYRF6936 power at 150mW in Devo 7E?
Try turning on has_ap-cyrf6936 in hardware.ini. If that doesn't do it. Set the 0 to a 1.
- saidem
07 Apr 2016 18:41 #46053
by saidem
I wanted to remove the Devo 7E module to replace the antenna and put it outside. But unfortunately I strongly pulled the module and I ripped connections from printed circuit. Could you tell me how to do for desoldering the module because you have to desoldering 7 connections simultaneously? That's the next time I take myself a little better !!!
Thanks a lot.
Thanks a lot.
- aMax
07 Apr 2016 19:04 - 07 Apr 2016 23:49 #46055
by aMax
Replied by aMax on topic Stock CYRF6936 power at 150mW in Devo 7E?
One save way is cutting each connection at the RF module just at the edge.
Clean the solder points on the module and cut the connection one by one (dremel or scalpel).
Secure this area with tape if using a dremel......
After lifting the module you can remove therest remaining parts from the main board, .....one by one, with ease.
Last edit: 07 Apr 2016 23:49 by aMax.
- czajunia
08 Apr 2016 00:32 #46083
by czajunia
Thanks a lot guys. It was actually enabled but set to 0 for some reason. It works as it should now.
- saidem
08 Apr 2016 07:47 #46097
by saidem
Thank you very much for your answer and photo, I would not dare cut the module with the dremel, but I think this is the right solution. Otherwise you would have a picture with the Devo 7E Module removed and replaced with the Devo8 Module / 12. Because I want to see the detail of welds and connections.
A big thank you again for your response.
- ursus69
08 Apr 2016 09:16 #46102
by ursus69
Replied by ursus69 on topic Stock CYRF6936 power at 150mW in Devo 7E?
See the connections here!!
www.hacksmods.com/2014/10/wk-devo-s-mod-module-for-devo7e/
- saidem
08 Apr 2016 14:21 #46113
by saidem
In the photo I can not see well, but I think all the old circuit is removed even at the connections of the original one, is that it? Because at this place it's pretty difficult to do!
- ursus69
08 Apr 2016 15:10 #46115
by ursus69
- saidem
08 Apr 2016 15:40 #46116
by saidem
Then it's very clear. I had not seen it. Thank you and have a good weekend. Now I put myself in solders.
08 Apr 2016 20:29 #46127
It's set to 0 because the stock 7E doesn't have a PA in it. Or maybe the one it has is so crippled by the power reduction as to be useless.
czajunia wrote: Thanks a lot guys. It was actually enabled but set to 0 for some reason. It works as it should now.
- victzh
09 Apr 2016 04:25 #46154
by victzh
@saidem I use couple of tricks to desolder such things - solder wick or desoldering bride - it's a copper wick which dries out the solder - after this you'll find out that the module is not that strongly connected. For some especially stubborn places I use Chip Quik - it's a low temp solder which when mixed with blobs of solder your try to melt lowers their melting point significantly and it becomes possible to keep molten many pins at a time. You need to be careful with it - if it goes to unwanted place it will make it melt also. And you need to clean after it with mentioned wick very thoroughly.
- saidem
09 Apr 2016 08:44 - 09 Apr 2016 08:54 #46160
by saidem
I use the pump and desoldering wick, but it is still hard! The problem was with the 7 module connections through the printed circuit and their feed is on the other side. On this side there is the display and you can not drop it because it is welded on two sides and has 18 connections. We must be sure that the connections through the circuit well. But with all your advice it should go now.
Thanks a lot.
Thanks a lot.
Last edit: 09 Apr 2016 08:54 by saidem.
