Need help identifying RF module
02 May 2016 18:40 - 02 May 2016 18:45 #47598 by Josh69
Need help identifying RF module was created by Josh69
Hi! I need help to identify a RF module. The RF module is from a Helic Sky Max Vampire transmitter. This is my first post here on deviationtx :-)
drive.google.com/file/d/0B2u-o3FyPvNhbmV...00/view?usp=drivesdk
drive.google.com/file/d/0B2u-o3FyPvNhNjg...kU/view?usp=drivesdk
Last edit: 02 May 2016 18:45 by Josh69.
03 May 2016 02:27 #47618 by hexfet
Replied by hexfet on topic Need help identifying RF module
Maybe Beken2423 ? Likely nRF compatible if so.
03 May 2016 03:41 #47622 by victzh
Replied by victzh on topic Need help identifying RF module
Most probably it is Beken 2423 indeed. And it is compatible with nRF24L01+ as far as I can recall.
03 May 2016 21:32 #47698 by Josh69
Replied by Josh69 on topic Need help identifying RF module
Can i use this instead of a nRF24L01+? :)
03 May 2016 21:38 #47699 by victzh
You can try. In principle all the protocol file contain Beken initialization code so it should work.
04 May 2016 20:06 - 05 May 2016 00:51 #47771 by Josh69
Shall i just solder Power, Ground, SCK, MOSI, MISO and CSN to the transmitter? Should i solder together the power and CE? Txen what is that for?
I got deviation 5.0 on my devo 10
drive.google.com/file/d/0B2u-o3FyPvNhVm5...lU/view?usp=drivesdk
Edit. I soldered the RF module and it seems to work as it should.
Last edit: 05 May 2016 00:51 by Josh69.
Time to create page: 0.072 seconds
