Nano CP S pitch problem
- vmsda
03 May 2016 08:08 #47632
by vmsda
Nano CP S pitch problem was created by vmsda
Trying to fly the CP S with my stock 7E (stick mode 3, no mods as yet, nightly build aa82a64). It goes ok in normal mode (Fmode 0), but when I switch to Fmode 1, pitch does not respond to stick movement, altitude constant! Anybody come across this problem and have it solved? Thanks.
- Thomas.Heiss
03 May 2016 09:54 #47638
by Thomas.Heiss
Replied by Thomas.Heiss on topic Nano CP S pitch problem
Post your model.ini.
You probably missed a mixer for setting the correct pitch curve on F-Mode1.
- vmsda
03 May 2016 10:40 #47642
by vmsda
Replied by vmsda on topic Nano CP S pitch problem
This is a file I copied from somewhere, and since it is Standard GUI, I have tweeked some throttle and pitch values, that is all.Thomas.Heiss wrote: Post your model.ini.
- Thomas.Heiss
03 May 2016 11:57 #47647
by Thomas.Heiss
You seem to be missing a pitch curve for Hold too?
I can't tell where the problem is when looking at the model.ini. I will try to import it.
Have you already tried looking at the transmitter / channel monitor?
What are the values on CH6 / Virt3/Cyclic3? Do they change?
I am not sure if this might be a CH5 problem for maybe not setting the required NanoCPS stability/agility mode?? May a wrong value may confuse the Nano???
Too bad...I don't own NanoCPS...just had NanoCPx with no CH5 settings...
Maybe I find a way to test it nevertheless or looking in the manual.
...will be back...
...will be back...
- vmsda
03 May 2016 12:21 #47650
by vmsda
I went into the Channel Monitor. With the FMOD1 position, all channels, including Ch6 and Virt3 oscillate between 100 and -100. So this side of things looks ok.Thomas.Heiss wrote: You seem to be missing a pitch curve for Hold too?
...will be back...
Time to create page: 0.392 seconds
- Nano CP S pitch problem
