- HELP! Devo 7E won't boot. LCD lights up but is blank, Transmitter beeps twice
- RakelJamz
01 Nov 2016 17:29 #55587
by RakelJamz
HELP! Devo 7E won't boot. LCD lights up but is blank, Transmitter beeps twice was created by RakelJamz
Hello, this is my first posting, but I'm in desperate need of help. I recently purchased a Devo 7e transmitter, and flashed Deviation with no issues. I then attemted to install the nrf24l01 mod. Once finished, the transmitter will not boot. When i turn it on, it beeps twice, the LCD lights up, but nothing is displayed on the screen. I removed the nrf24l01 module, but the same thing happens: 2 beeps, LCD lights up but is blank. Anyone have any ideas? Thanks guys!
- HappyHarry
02 Nov 2016 19:31 #55626
by HappyHarry
Replied by HappyHarry on topic HELP! Devo 7E won't boot. LCD lights up but is blank, Transmitter beeps twice
have you removed all of the wiring from the module install? are there any shorts created by solder? have you tried reflashing deviation and replacing the file system (if you can get it to show up there of course)? what else have you tried to fix this issue?
- RakelJamz
04 Nov 2016 14:58 #55669
by RakelJamz
Replied by RakelJamz on topic HELP! Devo 7E won't boot. LCD lights up but is blank, Transmitter beeps twice
I have removed the module and attemted to clean up area. No visible solder splatter. The Lcd lights up but, nothing shows on it. Two ticks are audible when power is applied, but that is all. When the trim buttons are pressed, the remote still makes the sounds of trimming.
- HappyHarry
04 Nov 2016 15:12 #55670
by HappyHarry
have you tried re-flashing the firmware and replacing the file system contents? as it sounds like the filesystem is missing some data
- RakelJamz
04 Nov 2016 17:45 #55681
by RakelJamz
I haven't tried reflashing it as yet. However, i did try turning it on while holding the ENT button, and the transmitter acted as if it wasn't receiving power, and the LCD would no longer light up. I suppose I'll try hooking it up the my computer when i get home in a bit. Should I take the same steps I did when i first installed deviation?
- HappyHarry
04 Nov 2016 20:28 #55690
by HappyHarry
yes exactly the same, power up while holding ext and then flash the firmware, then power down, next power up while holding ext and copy across the file system
- RakelJamz
04 Nov 2016 20:49 #55691
by RakelJamz
Ok. I didn't update the file system the first time, i don't think. I used the Deviation installer, not the Walkera, if that matters. Is it just copy and paste into the root of the transmitter?
- RakelJamz
04 Nov 2016 22:47 #55694
by RakelJamz
So i reflashed the software, and copied the files. Now when the transmitter powers up it makes 3 beeps and the lcd comes on but it's still blank. No splash screen like the first time.
- HappyHarry
05 Nov 2016 02:13 #55702
by HappyHarry
what exact version of deviation are you installing?
- RakelJamz
05 Nov 2016 12:05 #55711
by RakelJamz
5.0
- RakelJamz
05 Nov 2016 13:45 #55712
by RakelJamz
The circuit board is clear of splatter, so i wonder why the lcd won't show any images, yet lights up?
- RakelJamz
07 Nov 2016 16:30 #55777
by RakelJamz
Went over the controller again to look for possible solder splatter, and still nothing. Any ideas what to check to find what's responsible for images to appear on the lcd?
- RakelJamz
07 Nov 2016 18:01 #55778
by RakelJamz
Ok, so i found that the lack of images on the lcd is due to a short around the vdd spot. If i lay a small piece of aluminum foil over the port, and apply pressure, the screen shows images! However, if i remove the pressure the image disappears. Anyone have any ideas?
- HappyHarry
07 Nov 2016 23:46 #55787
by HappyHarry
Time to create page: 0.103 seconds
