Hardware.ini file.
- saidem
22 Jun 2017 19:52 #63092
by saidem
Hardware.ini file. was created by saidem
Could you tell me why when I save the hardware.ini file on the computer everything is fine, but if I do it in the USB drive of the Devo 12S transmitter, always with Notepad ++ when I re open the page is empty. So I can not activate my module 4 in 1. I format the USB drive and every time it comes back.
Thank you for your explanation.
- saidem
23 Jun 2017 13:30 #63097
by saidem
Replied by saidem on topic Hardware.ini file.
In fact I found what was wrong: it was not necessary to modify the file on the USB drive directly. It must be modified on the computer, save it and once modified put it in the TX and no longer touch up. Tell me if it's normal or not?
Thank you very much to everyone.
23 Jun 2017 16:37 #63101
Replied by FDR on topic Hardware.ini file.
Had you unmounted the USB drive before you disconnected the TX?
- saidem
23 Jun 2017 18:26 #63102
by saidem
Sorry for my bad English, I guess demounted means disconnecting in a computerized way. Well no I switch off directly to the TX.
23 Jun 2017 18:57 #63103
Yeah, sorry!
I meant first properly disconnect the USB drive logically, before disconnecting the cable or turning off the TX.
I always do, and have no flash problems...
- saidem
23 Jun 2017 20:30 - 25 Jun 2017 13:18 #63104
by saidem
I have tried to do as you have written me and it's OK:) . That was my mistake. I never logically switch off, to go faster but this is not good! Thanks a lot for helping.
Last edit: 25 Jun 2017 13:18 by saidem.
Time to create page: 0.030 seconds
- Hardware.ini file.
