Memory Mod. On F7
- Bisky
11 Mar 2018 20:08 #68011
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic Memory Mod. On F7
Are u using DfuSe USB upgrade tool?
When u connect the transmitter in EXT + ON does it say DEVO-F7 program update?
does the pc find
does the pc find
- Quell
11 Mar 2018 20:30 - 11 Mar 2018 20:32 #68013
by Quell
Replied by Quell on topic Memory Mod. On F7
No EXT + ON and I get a blank screen, a blue blank screen.
Yes I'm using the Dfuse USB upgrade tool.
Last edit: 11 Mar 2018 20:32 by Quell. Reason: More
- Bisky
22 Mar 2018 14:37 #68274
by Bisky
Did you get it working?
- Quell
22 Mar 2018 14:46 #68276
by Quell
Nope as far as I can tell everything is correct with the XMS modification.
I am not very good with the computer so I am thinking that it might be a problem with the drivers and it won't reload deviation.
I only pad 30 dollars for the radio so I think I will just put it on Ebay as a parts radio and try to get my money back.
Unless you know someone who can use it.
- Bisky
22 Mar 2018 15:04 #68281
by Bisky
Do you get the Walkera defuse screen on EXT+ Switch ON?
- Quell
22 Mar 2018 15:10 #68282
by Quell
No just a blank blue screen, but this time I just reassembled it and when I turn it on I got the deviation version 5.0 screen and the strange one line menu. I played in the menu for a minute and shut it off, and then when I turned it on I am back to only getting the dimm Deviation usb screen.?? Weird
I have another radio and I'm tired of messing with this damb thing...
- Quell
22 Mar 2018 15:26 #68283
by Quell
No offense to you I'm at a dead end , thank you so much for your time and help!
- Bisky
22 Mar 2018 15:27 #68284
by Bisky
Hook it up to a computer, you should se a usb flash drive? If so, format it and copy files to it.
- Quell
22 Mar 2018 15:30 #68285
by Quell
OK I will give it a try in a little bit.
- Bisky
22 Mar 2018 15:47 #68286
by Bisky
I think the XMS mod was successful, but because the new chip is blank the devo goes into usb mode because the files it need to run are missing...
- Quell
22 Mar 2018 16:25 #68287
by Quell
I have a feeling that it's good also. I wish someone on here that is good with computers would install deviation for me
My computer will not recognized the radio so I'm stuck until someone can definitely install deviation or not?
- Bisky
23 Mar 2018 08:15 #68306
by Bisky
on EXT+ON you get this screen?
on ENT+ON?
If so, probably I could help you with drivers via remote connection...
on ENT+ON?
- Quell
23 Mar 2018 11:34 #68307
by Quell
EXT and on and I get a blue screen but it's blank nothing like what you show, it's the same bright blue but it's just blank.
- Bisky
23 Mar 2018 14:56 #68308
by Bisky
Pleas make a picture, how you moded the lines to the SMT32.
- Quell
23 Mar 2018 14:59 #68309
by Quell
OK I will get some pictures later today.
Time to create page: 0.497 seconds
- Memory Mod. On F7
