- DEVO 12S Nightly Builds only Black Screen
- Martin109
03 Apr 2019 18:05 #73672
by Martin109
DEVO 12S Nightly Builds only Black Screen was created by Martin109
I installed the DFplayer mini in my DEVO12S. In order to put this into operation then I wanted to install one of the current Nightly builds.
Can also install easily.
But no matter which nightly build I try it, it's always the same problem that always only turns black screen when you turn it on.
After that, the transmitter can not be switched off.
What am I doing wrong?
If I install the 5.0 final firmware everything goes again. But that's not with the DFplayer.
regards Martin
regards Martin
- Moeder
05 Apr 2019 07:22 #73699
by Moeder
Replied by Moeder on topic DEVO 12S Nightly Builds only Black Screen
There is a known issue with devo12s in current nightly, a fix is in the making. Please have a little patience.
- -=Hubi-Dirk=-
06 Dec 2019 15:24 #75535
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic DEVO 12S Nightly Builds only Black Screen
Hi Moeder,
today i try the actual nightly (2019-12-06). After flashing the screen is still black and the 12s cannot switched off (pulling the battery instead and went back to the former version).
Can you tell us when the fix will be available?
Dirk
Dirk
11 Dec 2019 13:19 - 11 Dec 2019 13:22 #75563
Replied by vlad_vy on topic DEVO 12S Nightly Builds only Black Screen
Try tomorrow's nightly build, I hope this is fixed now.
Last edit: 11 Dec 2019 13:22 by vlad_vy.
12 Dec 2019 12:25 #75565
Confirmed, now it works.
- -=Hubi-Dirk=-
12 Dec 2019 16:56 #75566
by -=Hubi-Dirk=-
Hi Vlad
yes, the Nightly from 12.12. works!
You are the man!
Thank you very much!!!
Best
Dirk
You are the man!
Best
Dirk
Time to create page: 0.274 seconds
