AUX5 does not calibrate with T8SG V2 Plus and V3
17 Apr 2019 02:09 #73954 by Ryou
AUX 5 does not store calibration values when performing analog calibration with T8SG V2 Plus. There is no problem with older firmware.
With the new T8SG V2 Plus (V3) carbon color, the 'saving' voice talks twice and says the 'welcome deviation' when the power is turned on.
18 Apr 2019 13:37 #73993 by Ryou
It was the same with two T8SG V2 Plus carbon patterns.
At power on, we talk that the audio is not relevant twice. The internal PCB has a new audio playback circuit.
Maybe you need some initialization? . Do you need hardware processing? .
19 Apr 2019 22:41 - 19 Apr 2019 22:44 #74023 by Pao
AUX5 of my T8SG V2+(carbon) does not work either.
Calibration rewrites < tx.ini > file as below.
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=0
min=0
zero=0
It is a bug of the Deviation.
Hardware is good.
Connect the USB and rewrite < tx.ini > file as below.
[calibrate6]
max=4095
min=0
zero=2047
Now AUX5 works.
Last edit: 19 Apr 2019 22:44 by Pao. Reason: - charactor not see
19 Apr 2019 22:46 #74024 by Ryou
Pao wrote: AUX5 of my T8SG V2+(carbon) does not work either.
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=0
min=0
zero=0
The calibration problem is working in the same way.
Are the audio problems the same? .
When I go into USB mode or DFU mode, I'm nervous.
It becomes a noisy transmitter.
20 Apr 2019 01:08 - 20 Apr 2019 01:09 #74025 by Pao
My T8SG V2+ also say "Saving Saving" when turn on it.
and when USB mode or DFU mode keep saying "Saving Saving Saving ..............".
I want it to be quiet quickly.
Last edit: 20 Apr 2019 01:09 by Pao.
20 Apr 2019 20:06 #74041 by Moeder
Both bugs will be looked into, thanks for reporting.
20 Apr 2019 22:53 #74048 by Moeder
Proposed fix for calibration issue:
github.com/DeviationTX/deviation/pull/862
Has to be tested yet, if you know how to compile deviation yourself please try it out and report back. Otherwise please have a little patience.
22 Apr 2019 11:43 #74081 by Ryou
I confirmed that it works properly.
Thank you.
22 Apr 2019 11:51 #74082 by Ryou
Postscript
The calibration of AUX5 was saved correctly.
The audio problem does not seem to be improved. I do not seem to turn on and make two random utterances.
22 Apr 2019 12:31 #74084 by 52dgj
The F12E and AUX7 built every night also have this problem. Manually modify the tx.ini file to work properly.
22 Apr 2019 19:09 #74091 by Moeder
Should be resolved in nightlies (the calibration issue, not the voice one).
28 Apr 2019 22:50 - 28 Apr 2019 22:50 #74167 by Moeder
As I have no V3 (carbon), I can't look deeply into the voice issue. You could try the attached build (based on current nightly) and see if the issue is fixed. Otherwise I'd suggest removing the mp3 for saving, as there is only really two situations where it should be called in mixer setup.
Last edit: 28 Apr 2019 22:50 by Moeder.
29 Apr 2019 06:24 #74168 by Ryou
Since the correction version of the calibration problem of AUX5, the two random utterances at power on have disappeared.
However, the power on "wellcome deviation" may not come true.
Your 6dfc826 version was the same.
Thank you for your response.
29 Apr 2019 08:26 #74169 by Moeder
Missing welcome message is a known issue. Haven't found a good solution yet. Please try out the build 6dfc826 a little bit, it has reworked voice code. It works fine for me, but another tester would be good to have before pulling in the changes.
21 Sep 2019 19:26 #75135 by xeutrex
Time to create page: 0.125 seconds
