Firmware update under Linux
- Gall
21 Sep 2012 20:05 - 22 Sep 2012 07:48 #1762
by Gall
Firmware update under Linux was created by Gall
I'm trying to write Deviation dfu to Devo8 under Linux using dfu-util 0.6. No success. Is it possible?
I did the following:
dfu-util -d 0483:df11 -a 0 -D deviation-devo8-v1.1.2.dfu
Tried with -R option as well. It seems to upload data but does not leave DFU mode then.
Last edit: 22 Sep 2012 07:48 by Gall.
- wuselfuzz
24 Sep 2012 07:35 #1771
by wuselfuzz
Replied by wuselfuzz on topic Firmware update under Linux
I'm using dfu-util 0.6 on OS X 10.8, works fine.
Leaving DFU mode through dfu-util doesn't work, though, but flashing, then manually resetting the transmitter works.
From the Makefile:
From the Makefile:
flash: devo8.dfu
dfu-util -a 0 -D devo8.dfu- Gall
24 Sep 2012 18:05 #1775
by Gall
Replied by Gall on topic Firmware update under Linux
Hm, reset did not work in my case. Even removing the battery had no effect. It just returns into firmware update mode immediately.
Maybe I have to try JTAG to debug the issue.
- Gall
11 Oct 2012 14:52 #2164
by Gall
Tried Windows, still no success even with native Devo firmware. The TX just does not leave upgrade mode at all even after removing the battery.
Now going to use JTAG to reflash everything including the bootloader.
11 Oct 2012 16:04 #2169
Replied by PhracturedBlue on topic Firmware update under Linux
Are you sure you upgraded (rather than uploaded) the Devention firmware using Walkera's dfuse tool? The only reason it would boot right to the bootloader is if (a) the ext button was stuck or (b) the checksum was wrong. The dfuse tool from walkera will always write the right checksum (this is not true of the dfuse tool from STM)
- Gall
12 Oct 2012 17:36 #2181
by Gall
I'm pretty sure the upgrade failed and the checksum is wrong. For some strange reason dfuse does not see the TX anymore while dfu-util still does. Looks like the TX's bootloader is stuck in some strange state preventing it from normal upgrade.
I think I'll better treat the CPU as empty and reflash everything. At least it will be readable then. Probably I'll end with a custom bootloader
Time to create page: 0.174 seconds
- Firmware update under Linux
