- Full servo travel over half of the rudder stick?
- Staron
15 Nov 2020 04:33 #77012
by Staron
Full servo travel over half of the rudder stick? was created by Staron
Is there a way to get set up my rudder stick to make a servo travel the full range while just moving the stick half way?
- propnut
15 Nov 2020 14:48 #77013
by propnut
Replied by propnut on topic Full servo travel over half of the rudder stick?
Create a curve and then assign that to the channel
- Staron
16 Nov 2020 05:08 #77017
by Staron
Replied by Staron on topic Full servo travel over half of the rudder stick?
I'm sorry but I don't know what that means. Is that done in the mixer for the rudder channel?
- -=Hubi-Dirk=-
16 Nov 2020 09:05 - 16 Nov 2020 09:06 #77018
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Full servo travel over half of the rudder stick?
Try it with a 5-point curve the way you need it. The values in the example are:
Point 1: -100
Point 2: -100
Point 3: 0
Point 4: 100
Point 5: 100
Attached are two pictures for overview.
Point 1: -100
Point 2: -100
Point 3: 0
Point 4: 100
Point 5: 100
Last edit: 16 Nov 2020 09:06 by -=Hubi-Dirk=-.
- Staron
16 Nov 2020 19:17 #77021
by Staron
Thank you, that helped . I guess my issue is getting my servo to move the full 180 deg. verses only 90 deg.
- propnut
16 Nov 2020 23:17 #77022
by propnut
What in either direction of the stick or only in one direction ?
- Staron
17 Nov 2020 00:35 #77023
by Staron
The servo only moves 45 deg each way.
- -=Hubi-Dirk=-
17 Nov 2020 07:12 #77025
by -=Hubi-Dirk=-
Is the servo specified for 180° movement?
Btw: It would be nice to get some more information about what you have in mind. Describe the application with your words to make it clearer and easier to understand.
Time to create page: 0.464 seconds
