- Does Deviation has potential to get CloneTX funct?
- BlackLotus
12 Mar 2021 01:52 - 12 Mar 2021 01:55 #77310
by BlackLotus
Newbie who using Devo 10
Does Deviation has potential to get CloneTX funct? was created by BlackLotus
Very thanks for easy and powerful firmware.
I hope to using Cloning frsky TX function, like other 4in1 multi-module.
Or it's already done here, but I can't find?
Last edit: 12 Mar 2021 01:55 by BlackLotus.
12 Mar 2021 04:31 - 12 Mar 2021 04:33 #77311
Replied by vlad_vy on topic Does Deviation has potential to get CloneTX funct?
You can't clone current transmitter ID, but you can use the same ID with different Deviation Tx. You will need rebind all receivers with any transmitter.
In the top-section of hardware.ini (above [modules]), set some random 8-character hex value:
txid = xxxxxxxx
(each x can be 0-9,a-f)
Generator:
rumkin.com/tools/password/pass_gen.php
txid = xxxxxxxx
Generator:
Last edit: 12 Mar 2021 04:33 by vlad_vy.
- BlackLotus
12 Mar 2021 04:45 #77312
by BlackLotus
Replied by BlackLotus on topic Does Deviation has potential to get CloneTX funct?
Oh, very thanks vlad_vy for quick reply.
But I can't understand needs of matching Transmitter ID to another if it still needs to rebind.
Sorry for question again.
12 Mar 2021 07:18 #77313
If you change TXID to custom, you need rebind model once. You don't need bind model to second transmitter with the same TXID.
- BlackLotus
12 Mar 2021 08:23 #77314
by BlackLotus
Thanks for perfect explanation!
Very happy to knowing that
- Fernandez
13 Mar 2021 21:09 #77315
by Fernandez
Replied by Fernandez on topic Does Deviation has potential to get CloneTX funct?
And how to read the TxID from your radio, if you have not entered your own Custom TxID in hardware.ini inside your excisting radio? Can we make it visible ?
Time to create page: 0.999 seconds
