Live Channel configuration
- NewJocker
22 Oct 2012 11:04 - 22 Oct 2012 11:09 #2372
by NewJocker
Live Channel configuration was created by NewJocker
For easiest model tweaking, i think the channel configuration page must be in live. It is not easy to trim the servos (subtrim, scale, min & max) when you must valid by pressing "ok", return to chanel configuration, modify value then press "ok" again to test effect, etc....
This page must be in live, but if you press "cancel", the values return to previous state, else "ok" valid changes.
Renaming channel will be a plus too..
What do you think about that?
Thanks for this best firmware. Waiting for the new version.
Best regards.
Best regards.
Last edit: 22 Oct 2012 11:09 by NewJocker.
- suvsuv
23 Oct 2012 04:44 #2384
by suvsuv
Replied by suvsuv on topic Live Channel configuration
In devo10, Limits will be saved in partially live, which just means modification of a limit item will be saved when the ENT key is pressed. There will be no cancel and save buttons in the mixer-limit page.
How do you feel about it, PB?
23 Oct 2012 12:47 #2390
I like the idea of having the update be live but Cancel revert it.
Replied by PhracturedBlue on topic Live Channel configuration
For the limits page it is probably ok. For the mixer configuration, it is probably not a great idea.suvsuv wrote: In devo10, Limits will be saved in partially live, which just means modification of a limit item will be saved when the ENT key is pressed. There will be no cancel and save buttons in the mixer-limit page.
23 Oct 2012 12:57 #2391
Yep, that's the best way.
Replied by FDR on topic Live Channel configuration
PhracturedBlue wrote: I like the idea of having the update be live but Cancel revert it.
- suvsuv
- NewJocker
23 Oct 2012 14:37 #2393
by NewJocker
Yes, is very usefull to tweak the channels in live mode on the playfield, especialy for the subtrims. And if i make a mistake : taadaa: press cancel button and retrieve the previous values.
PB: Can you implement this feature in the next dev8 firmware?
Replied by NewJocker on topic Live Channel configuration
23 Oct 2012 17:46 #2394
File a ticket on bitbucket. It is how I keep track of my to-do list
Time to create page: 0.325 seconds
- Live Channel configuration
