DEVO 8 Brightness, Contrast, Time
- clearprop88
10 Jan 2013 18:43 - 10 Jan 2013 18:44 #4902
by clearprop88
DEVO 8 Brightness, Contrast, Time was created by clearprop88
Is there a way to adjust the BRIGHTNESS, CONTRAST, AND TIMER on my DEVO 8 on screen.
I see that I can adjust it by going into the "tx" file, but I don't know what the max values are.
I set BRIGHTNESS=10, CONTRAST=10, AND TIMER=30000.
The defaults are set at B=5, C=5, T=20000
Can I set these parameters on screen?
Last edit: 10 Jan 2013 18:44 by clearprop88. Reason: correstion
10 Jan 2013 18:54 #4903
Replied by rbe2012 on topic DEVO 8 Brightness, Contrast, Time
Brightness and timer is set in teh transmitter config (scroll down one page).
Haven't seen Contrast yet somewhere in the gui.
- clearprop88
10 Jan 2013 20:26 #4909
by clearprop88
Replied by clearprop88 on topic DEVO 8 Brightness, Contrast, Time
OK. Got it thanks.
What does Dimmer Target do?
10 Jan 2013 21:40 #4910
When you don't make any input for the time set in "timer" the brightness will be set to this value (normally off). You get the old brightness when making inputs (inputs = touchscreen and the menu buttons, not those for controlling the heli/plane...)
- clearprop88
10 Jan 2013 22:42 #4911
by clearprop88
It was set to off.
Sounds good it should save the battery.
The screen is readable in sunlight. I thought it would be worse.
Time to create page: 0.287 seconds
- DEVO 8 Brightness, Contrast, Time
