help changing tx ini please
22 Feb 2014 06:07 #20730 by Birdman
help changing tx ini please was created by Birdman
Hi all.
Need help changing tx.ini with programmers notepad or similar, please.
Adding A7501 module, I should be ok on hw side, but have no idea how to change tx ini. Have installed Programmers notepad but do not know what to do next.
I do know what to change and what to change it to, but thats it.
Have done a search with no luck.
Bm
22 Feb 2014 10:45 #20733 by Birdman
Replied by Birdman on topic help changing tx ini please
Proto X is flying with Devo8, used board from original tx.
Thanks again
Bm
22 Feb 2014 13:27 #20735 by John-Boy
Replied by John-Boy on topic help changing tx ini please
Hi Birdman,
You say you used the 7501 from the Estes Proto X? I thought that little transmitter had an all-in-one board?
John L.
22 Feb 2014 14:07 #20736 by Birdman
Hi John,
Correct, no separate module. I cut out a section of the pcb that contains necessary parts, a small rectangle about 46 x 11mm. Appears to have small amp.
First impressions of quad not good, but now it is calibrated and dialed in, it is sweet as.
Bm
22 Feb 2014 14:14 - 22 Feb 2014 14:15 #20737 by Birdman
pic shows where i cut pcb, rest is in tx
will dig it out if anyone wants more info
Bm
Last edit: 22 Feb 2014 14:15 by Birdman.
22 Feb 2014 14:51 #20741 by John-Boy
Any pictures of your connections to the cutout board? Thanks... ;)
22 Feb 2014 22:40 - 23 Feb 2014 05:47 #20763 by Birdman
Last edit: 23 Feb 2014 05:47 by Birdman.
Time to create page: 0.212 seconds
