tactile sceen not workingHello
- pypass
03 May 2014 14:10 #22861
by pypass
tactile sceen not workingHello was created by pypass
is anyboby got this problem and can help me to solve it?
The touch tactile working well and with any reason all the data on graphics for all curve (pitch etc...) can be set.
The problem is worst in left bottom of the screen on the H point of the curve.Majority of the time the touch do not worh and sometime its a another point off where i touch is working.
I am not good in electronic but i doubt is the screen because in the model menu and at the touch sreen calibrate all the touch workind at the place where it's do not work for the curve
tanks a lot and if you could give a little answer about what i have to check
- pypass
08 May 2014 13:36 #23006
by pypass
Replied by pypass on topic tactile sceen not workingHello
Is it possible to change the tactile only ?
08 May 2014 13:54 #23008
Replied by PhracturedBlue on topic tactile sceen not workingHello
I assume this is a Devo8? replacing the screen on the devo8 should be possible. You would need to contact Walkera for a replacement though.
Time to create page: 0.189 seconds
- tactile sceen not workingHello
