Throttle hold & negative pitch
- John-Boy
13 May 2014 02:26 #23168
by John-Boy
Throttle hold & negative pitch was created by John-Boy
Hi there,
I'm using the Standard interface. When I engage throttle hold the collective goes full negative.
Is there a way to adjust the negative pitch, when throttle hold is used, while using the standard gui?
Thanks in advance...
JL
JL
- John-Boy
14 May 2014 23:11 #23241
by John-Boy
Replied by John-Boy on topic Throttle hold & negative pitch
Anyone done this before?
- tmcg
15 May 2014 12:14 #23256
by tmcg
Replied by tmcg on topic Throttle hold & negative pitch
There is a separate pitch curve for when in "throttle hold" mode. In standard interface, go into pitch curve settings, then scroll through modes until you get to "thr hold" mode. You likely have Enabled set to ON. This is the curve when you hit throttle hold switch. If you set Enabled to OFF then I suspect it disables separate pitch curve when throttle hold is activated, but I haven't tried that.
I like separate throttle hold pitch curve, and I have mine set linear from -100 to +100 because I use that mode to tune my heli and FBL controller on the bench without having to physically disconnect the motor leads. But I've also made the mistake during flight of hitting TH while also pulling pitch stick full negative (old habits die hard), which tends to cause more crash damage.
- John-Boy
16 May 2014 03:57 #23272
by John-Boy
Boy, do I feel stupid...
Thanks for pointing the settings out for me.
Time to create page: 0.093 seconds
- Throttle hold & negative pitch
