Emulator for devo7e with 2x2 switch support
- Alexfmx
15 Jul 2014 23:47 #24611
by Alexfmx
Emulator for devo7e with 2x2 switch support was created by Alexfmx
Does anyone know how i enable extra switch support for the devo 7e emulator?.
I tried downloading nightly build and copied the file system and also enabled 2x2 switch in the "hardware.ini" file.
Still not showing the extra channels did i miss something?
Alex
Alex
- D_an_W
16 Jul 2014 17:18 #24618
by D_an_W
Replied by D_an_W on topic Emulator for devo7e with 2x2 switch support
This is how my Hardware.ini switch section looks (2x3way switches)...
;switch_types: 3x2, 3x1, 2x2
extra-switches=3x2*** Walkera Devo 10 * 4-in-1 Module * Deviation v5 *** *** Walkera Devo 7E * A7105 Module * 2x 3 Way Switches * Power Mod * Deviation v5 ***
- Alexfmx
17 Jul 2014 15:09 #24638
by Alexfmx
Replied by Alexfmx on topic Emulator for devo7e with 2x2 switch support
It looks exactly like mine but the gui on the emulator still does not show the extra switches
I unpacked the emu then added the hardware file from a nightly build and updated it with the correct switches, i've also copied the whole filesystem from the nightly to the emu but no luck at all.
- Daryoon
17 Jul 2014 18:14 #24644
by Daryoon
Replied by Daryoon on topic Emulator for devo7e with 2x2 switch support
It works just fine for me.
Download the Devo 7e emu.
Edit the hardware.ini file to enable the extra switches. Then the emu runs and you can select the extra switches like you would from the actual radio.
Are you using the nightly release or official 4.01 emu? I don't recall if the official 4.01 firmware has the extra switch code added to it yet.
Time to create page: 0.037 seconds
- Emulator for devo7e with 2x2 switch support
