Devo 8s users please.
06 Aug 2014 20:12 #25061 by Blayd
Replied by Blayd on topic Devo 8s users please.
PB might be able to take a look and maybe he'll see something that could lead to what is causing the reboots???
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
17 Aug 2014 15:27 #25242 by StocKi
Replied by StocKi on topic Devo 8s users please.
Hi, I've recently been using a Devo 8s on Deviation and I dont get the icons for the menu screen. my screen looks like the pic in the second post. is this normal?
17 Aug 2014 21:56 #25252 by Blayd
Got a few questions for ya....
Are you in the advanced menu?
It would help if you posted some pics maybe...The post you refer to is one menu showing channel assignments I believe, so I'm not sure what exactly you mean.
I am using the Devo 8S on Deviation 4.0.1 on all 4 of my heli's, using the advanced menu for set up.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
18 Aug 2014 14:11 #25260 by StocKi
Hi, thankyou for responding, how do you turn advance menu on please? I'm not sure on still noobish :unsure:
18 Aug 2014 22:02 - 18 Aug 2014 22:07 #25272 by Blayd
Just want you to know, you can set up in the standard GUI. I'm just used to the advanced.
Not sure but you may already be in the advanced GUI...
When you start Deviation, touch the helicopter pic, this should bring you to a bunch of icons if your in the Standard GUI. ( If not, your already in the advanced GUI )
If you are in standard GUI, then touch the icon that looks like a wrench. This brings up the "model set up" screen.
If you touch next to where it says " Mixer GUI", you can change to the advanced GUI.
Right above the "mixer GUI" is "File".
It will say "load" in the option tab....if you touch the little arrows, you can change it to a few different things, the one you want is "template"
Touch the word template, and it gives you optional templates to load. I use the 6 channel helicopter template as a starting place.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Last edit: 18 Aug 2014 22:07 by Blayd.
25 Aug 2014 05:56 #25387 by StocKi
Thankyou Blayd, yes that was the cause. I've only recently acquired this Devo 8s and it has been a bit of a learning curve.
Thanks again.
27 Aug 2014 20:12 - 27 Aug 2014 20:14 #25409 by Blayd
No problem, I'm STILL learning.
Currently, I'm flying three 500's and my 700 on the latest stable release of Deviation 4.0.1. Takes a bit to get it figured out, but it is pretty simple to get a heli set up once you start to understand the way things work. I dont have a full understanding yet of scratch building a complex mixer, but I can work my way to a good decent set up on a 6 channel heli. BUT... mine are all flybarred heli's, so I dont have any experience in setting up Deviation on a FBL machine yet. Maybe next spring.. then I will need some help. :P OK.. OK.. ALOT of help... ;)
The 700 is still got me alittle nervous, since I can only fly in a flight field at a public park, so right now, it only flies if the place is 100% empty, but I am getting VERY confident in it. The range checks have been excellent. All the 500's are flying in Devo protocol, on the 802Rx's, the 700 is flying on the 2801 protocol, with a 2801Pro Rx.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Last edit: 27 Aug 2014 20:14 by Blayd.
Time to create page: 0.975 seconds
