DEVO 12E
17 Mar 2015 19:11 #29785 by schwarzsurfer
Replied by schwarzsurfer on topic DEVO 12E
Very nice! I hope it works :)
17 Mar 2015 19:38 #29786 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 12E
I also added an article about the Devo12E with my findings so far
17 Mar 2015 21:10 #29789 by netnerd
Replied by netnerd on topic DEVO 12E
Awesome job, PB. I think you're right about B0 considering the similarities between the two boards (seems to be the only unused ADC pin). Since PB9 can act as USART, I'd imagine it's related to debugging and possibly just moved from the DEVO 10 (I'd imagine that the similar trace below it connects to B8).
21 Mar 2015 19:55 #30009 by schwarzsurfer
Did anyone try this out? :whistle:
03 Apr 2015 18:35 #30759 by warrenhdavis
Replied by warrenhdavis on topic DEVO 12E
I uploaded the test build a couple of times but my F12E would not turn on after leaving DFU mode each time. I was able to re-enter DFU mode again after unplugging the battery and put back the stock 15A firmware. I would love to get this going since I want to use a Frysky D4R-II with it.
03 Apr 2015 19:22 #30762 by schwarzsurfer
This is for Devo 12E, not for Devo F12E!
15 Apr 2015 09:58 #31201 by dc59
Replied by dc59 on topic DEVO 12E
Is there anyone try PB's test build on DEVO 12E?
Can it work?
Thanks.
13 Jun 2015 12:48 #34003 by dlawso
Replied by dlawso on topic DEVO 12E
Have loaded the firmware. no USB logo and only darker Monitor could only major disconnect the battery switched off again.
15 Jul 2015 17:33 #35486 by Dj_Garfield
Replied by Dj_Garfield on topic DEVO 12E
The Same for me , I tested with the 2 FW posted , but the first made a Pixelised Black Screen , and the second one Nothing on the screen and nothing on the Rx , the light stay blinking on my Multirotor :)
Gone back to original FW :(
16 Jul 2015 16:09 #35530 by PhracturedBlue
I don't understand.
Did you read this post:
deviationtx.com/forum/3-feedback-questio...devo-12e-white#35053
That version will not show anything on the screen and it won't work with your model. It should let you trun on/off with the power switch, and it should enter USB mode (plug the tx into your pc, and turn it on while holding no buttons...your PC should detect it)
19 Jul 2015 11:26 - 19 Jul 2015 11:29 #35651 by Dj_Garfield
Yes I read the post , and knew that it could works but W/O displaying anything .. but I wrote that the Radio didn't link to my Reciever on the Multirotor ... so I dont works on my radio :)
I just wanted to give you a report , and if you need some other information , just ask me :) I will be happy to help you if you ( or somebody else ) plan to work on it .
I can't believe that we are not enough 12E users asking for a mod for this Radio that motivate some good developers :) After that if this is Impossible Mission to do it with specialy the 12E Radio , I understand the fact that we have to stay with Stock Firmware :)
Last edit: 19 Jul 2015 11:29 by Dj_Garfield.
02 Aug 2015 19:36 #36488 by marco899
Replied by marco899 on topic DEVO 12E
I flashed mine but didn't save the Original firmware. can someone send it to me? onbekendmarco at Hotmail.com
02 Aug 2015 19:41 #36490 by TomPeer
Replied by TomPeer on topic DEVO 12E
02 Aug 2015 19:48 #36491 by marco899
Thanks :cheer:
13 Feb 2016 02:38 #43073 by nwoodschris
Replied by nwoodschris on topic DEVO 12E
Any update. I am going to buy either a 10 or 12E. I would only want the 12E if I could use the wireless buddy box with my other Devo 10. PhracturedBlue what do you say?
13 Feb 2016 09:42 #43084 by FDR
Replied by FDR on topic DEVO 12E
There is no wireless body boxing in the DEVO transmitters.
There is only a wireless model config transfer you can use to have the same model config in both transmitters in order to use boddy boxing.
And no deviation doesn't have the wireless model config transfer, but it doesn't have to use the same model config on both transmitters either...
27 Feb 2016 03:53 #43750 by darthnugget
Replied by darthnugget on topic DEVO 12E
www.deviationtx.com/forum/how-to/5471-ho...with-deviation#43744
This is how I was able to load my F12E, and I have read that the F7 might work the same way.
23 Jun 2016 21:20 #51011 by sriniak
Replied by sriniak on topic DEVO 12E
Any Update? I bought DEVO 12E thinking it is similar to DEVO 10 with extra channels and can load DeviationTx (my bad for not checking the supported models!!) Appreciate if someone can confirm working and a video if possible for the configuration and settings. :dry:
29 Dec 2016 22:50 #57345 by robca
Replied by robca on topic DEVO 12E
sriniak wrote: Any Update? I bought DEVO 12E thinking it is similar to DEVO 10 with extra channels and can load DeviationTx (my bad for not checking the supported models!!) Appreciate if someone can confirm working and a video if possible for the configuration and settings. :dry:
Just in case you have not seen this yet: www.deviationtx.com/forum/6-general-disc...ber-sale-devo-12e-75
There are nightly builds now
18 Jan 2017 15:15 #58120 by ando1
Replied by ando1 on topic DEVO 12E
I just loaded the latest nightly build on my new 12E and it works fine. One thing to note, if you are installing the 4in1 module, use the picture for the 10E for where to solder the wires.
Andy
Time to create page: 0.103 seconds
