Install/Remove Deviation on DEVO 7e some questions
- jens
24 Oct 2014 06:15 #26157
by jens
Install/Remove Deviation on DEVO 7e some questions was created by jens
i am new, and just get an genius cp v2 with a devo 7e.
I read the instructions to install the deviation firmware on 7e.
"NOTE: As a result of memory limitations with the Devo7e firmware, the original models will be lost when switching to Deviation"
I have some questions now:
What does this mean? If i remove the deviation firmware and reinstall the original firmware i can't fly any heli anymore?
Is it possible to reinstall original firmware? Is it possible to save the models before installing deviation?
Jens
Jens
24 Oct 2014 09:59 - 24 Oct 2014 09:59 #26158
Replied by vlad_vy on topic Install/Remove Deviation on DEVO 7e some questions
Yes and Yes. You can reinstall original firmware. You can save and load original models with DFuse Upgrade tool (at 'Config' tab, one by one).
Last edit: 24 Oct 2014 09:59 by vlad_vy.
- jens
24 Oct 2014 14:46 #26159
by jens
Replied by jens on topic Install/Remove Deviation on DEVO 7e some questions
Ok, thanks for the quick reply
next question now:
how to save the model files from the devo 7e?
I startet the DFuse Upgrade Tool -> Config Tab.
to save the models i have to use the "upload file"?
to upload them into the devo 7e i have to use the "upgrade file" ?
Where can i find which models on the devo 7e saved?
Where can i see which firmware is installed at the moment on the devo 7e?
next question now:
25 Oct 2014 05:09 #26161
Right. First, select slot number (model number), then 'upload' to save model to new file or 'upgrade' to load model from selected file. Then select next slot and repeat this process up to your last model.
I don't remember there it is, but you can find Devo 7e version at Tx menu.
jens wrote: I startet the DFuse Upgrade Tool -> Config Tab.
- jens
26 Oct 2014 16:53 #26175
by jens
Thank you vlad_vy. Got it now
greetings
jens
greetings
jens
Time to create page: 0.207 seconds
- Install/Remove Deviation on DEVO 7e some questions
