NRF24L01
- alex367
05 Jan 2015 20:16 #27522
by alex367
NRF24L01 was created by alex367
Hi Guys,
is this der right Modul that i need...... ??
www.amazon.de/SainSmart-NRF24L01-drahtlo...-2&keywords=NRF24L01
05 Jan 2015 22:04 #27523
Replied by hexfet on topic NRF24L01
That module will work. It does not have a power amplifier so range will be limited (~30m), but that may be all you need with small models.
A longer range version is this module . It's a little more complicated to install because it requires a separate antenna.
- alex367
- robca
05 Jan 2015 23:56 - 06 Jan 2015 13:34 #27525
by robca
Replied by robca on topic NRF24L01
No eBay APP ID défined in Kunena configurationOr something like this, which has the power amplifier and includes the antenna already (ceramic antennas are supposed to work very well)
(weird, eBay link not working... let's try this www_ebay_com/itm/1PCS-2-4G-NRF24L01-PA-LNA-Wireless-Module-with-Ceramic-Antenna-for-Arduino-M79-/351252838137?pt=LH_DefaultDomain_0&hash=item51c84cf6f9)
(it's from China, though)
Last edit: 06 Jan 2015 13:34 by robca. Reason: eBay link not working
- alex367
06 Jan 2015 11:03 #27530
by alex367
Replied by alex367 on topic NRF24L01
Is this the correct manual for my module:
www.deviationtx.com/forum/6-general-disc.../3815-nrf24l01#27524
- robca
06 Jan 2015 13:28 #27532
by robca
Your link doesn't refer to a manual, just a post on this thread...
Assuming you have a Devo 7e, start here: bitbucket.org/PhracturedBlue/deviation/w...Devo7eModuleInstall/
and your module pinout is just like this: bitbucket.org/PhracturedBlue/deviation/w...aycomitm400611170500 (match the colors)
The wiring changes depending if you use the nightly or 4.01. The old wiring (for 4.01) also works for nightlies, so it's the "safe choice". I connected all of mines with the new wiring, though, since it uses less power, and will work in the future (and I only use the August nightly build anyway)
- aMax
- alex367
- alex367
- robca
- robca
06 Jan 2015 22:45 #27545
by robca
Since you have a Devo10, you cna start here bitbucket.org/PhracturedBlue/deviation/wiki/Devo8ModuleInstall
Personally, I would suggest getting more familiar with Deviation and the various builds first, before starting to solder additional modules. You want to make sure everything works reliably before starting to add more modules and potentially having more issues to troubleshoot
When you select the protocol, Deviation automatically enables only the required module. You can have up to two additional modules beyond the default one, or up to three if you build the multimodule (in your case not needed)alex367 wrote: Sorry if I ask again.
But if I want to use my Walkera receiver I just need switch between Walkera Receiver and The other Protocols in the Transmitter menue ??
Or do I have to make the module switchable ??
Time to create page: 0.043 seconds
- NRF24L01
