Module Question for Devo 7E
- bugman72
16 Feb 2015 16:52 #28747
by bugman72
Module Question for Devo 7E was created by bugman72
I am new to the Deviation scene and just received my Devo 7E last Thursday. I've already loaded Deviation on it and everything SEEMS to be working. I say "seems to be" only because I currently do not own any craft that use the protocols NOT requiring additional modules. That is where my questions lie.
When I purchased my 7E from Banggood, I also purchased two modules: an A7105 for my Hubsans and Proto Xs and a NRF24L01 for my Syma X5C and Dromida Ominus. Below are the links to the two modules that I purchased.
A7105 Module
NRF24L01 Module
Now, I'm pretty sure that I'll be good to go with the A7105 module. My question/concern is more directed towards the NRF24L01 module. The one I purchased has an external antenna and, after further reading on the forum, appears to NOT have a PA. Am I going to have trouble with this module once installed? Should I look in to purchasing a different module? Since I fly my Dromida more than my other quads, I am most concerned with making sure this module will work properly.
If this isn't the one I should have purchased, does anyone have a suggestion on which module I should get? Does Banggood have one that will work that I could get in exchange for the one that I hope to receive soon?
A7105 Module
NRF24L01 Module
- Durete
16 Feb 2015 16:58 #28749
by Durete
Replied by Durete on topic Module Question for Devo 7E
The A7105 Module is ok, but the nRf24l01 module will have a weak range for the Ominus. Think about buy another one with PA.
- bugman72
16 Feb 2015 17:10 #28750
by bugman72
Replied by bugman72 on topic Module Question for Devo 7E
So, it appears that this might be the one I should get, correct?
MassiveRC NRF24L01 Module
I am then only to assume that I need to get an antenna for this board as well. Is this what I need?
MassiveRC UFL IPX Antenna
- Durete
16 Feb 2015 17:15 #28752
by Durete
Sorry, I forget to put the link for the good one.
This one works perfect, only need to add your own antenna:
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
Also, you can but this one including antenna:
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
I installed the second one, ripping the antenna case to install inside the TX.
- Durete
16 Feb 2015 17:16 #28753
by Durete
Yes, your links from Massive are Ok.
bugman72 wrote: So, it appears that this might be the one I should get, correct?
Time to create page: 0.275 seconds
- Module Question for Devo 7E
