Antenna for "recommended" NRF24L01 module (Devo 7e
- Gerhard_H
18 Feb 2015 07:16 - 18 Feb 2015 07:16 #28797
by Gerhard_H
Antenna for "recommended" NRF24L01 module (Devo 7e was created by Gerhard_H
I have a working module in my Devo 7e, but not the "recommended" one (antenna printed on the board). Since all these modules are cheap I purchased some of the right ones, but without antenna (don't know why . . .)
But as far as I can see it shouldn't be a problem to solder an antenna wire, the soldering point is shown on the picture.
Question : What do you people think ? How long has the wire to be ?
TIA
Gerhard
TIA
Gerhard
Last edit: 18 Feb 2015 07:16 by Gerhard_H.
- Cereal_Killer
18 Feb 2015 07:29 #28799
by Cereal_Killer
Replied by Cereal_Killer on topic Antenna for "recommended" NRF24L01 module (Devo 7e
What you've drawn the arrow to is only 1/2 of the antenna connection, it has a + and a -, aka the center pin and the shield. The arrow you've pointed out is the center pin, the body of the connector is the shield. You can solder a piece of antenna wire if you don't have one with that style connector but for best performance it should be shielded and make both connections, don't just use a single wire whip if you can help it.
You can often find those exact antenna on old 2.4ghz wireless networking gear and you can find that mini-coax antenna wire in almost anything that uses any type of wireless comms.
- robca
18 Feb 2015 08:15 - 18 Feb 2015 08:16 #28802
by robca
Replied by robca on topic Antenna for "recommended" NRF24L01 module (Devo 7e
Why solder when you can simply use one of these antennas
www.goodluckbuy.com/150mm-frsky-2-4g-rec...compatible-2pcs.html
You can't find a much cheaper 2.4G antenna anyway, and that one (or similar ones on eBay) will just snap on
Or, if you prefer, you can use something like this www.ebay.com/itm/1x-2-4G-2-4GHZ-PCB-Inte...w-BK39-/251748634777 , both styles work just fine (the eBay preview doesn't work for me: ebay.com/itm/1x-2-4G-2-4GHZ-PCB-Internal-Antenna-To-U-fl-IPX-Connector-10cm-Cable-new-BK39-/251748634777)
Last edit: 18 Feb 2015 08:16 by robca.
- Gerhard_H
19 Feb 2015 06:59 #28879
by Gerhard_H
Replied by Gerhard_H on topic Antenna for "recommended" NRF24L01 module (Devo 7e
Thanks a lot for reply
@Cereal_Killer
I had checked the solder points with an instrument therefore I do know where the hot spot is
@robka
Of course buying an antenna isn't an issue, just wanted to know.
Generally the radio is used for tiny helicopters so the range of the radio doesn't matter.
Maybe : The unit needs a capacitive load (long shielding of the antenna) for best results.
@Cereal_Killer
@robka
- ohaya
19 Feb 2015 13:49 #28887
by ohaya
Replied by ohaya on topic Antenna for "recommended" NRF24L01 module (Devo 7e
I thought that it wasn't a good thing to use these modules without an antenna attached? I've seen that warning like on MassiveRC's page:
www.massiverc.com/PrestaShop/en/331-4g-n...ireless-module-.html
I was just wondering....
Jim
Note: NEVER power on a video transmitter\receiver without the antenna installed. You will burn out the module if you do and will void your warranty.I was just wondering....
Jim
- Gerhard_H
19 Feb 2015 14:19 #28890
by Gerhard_H
"These" modules have the antenna printed on the board. What they don't have is an amplifier.ohaya wrote: . . . it wasn't a good thing to use these modules without an antenna attached? . . .
- ohaya
19 Feb 2015 14:22 #28891
by ohaya
Ok, thanks. Maybe I was mixing up reading the posts. I thought the one that was linked was one with a PA and an SMA antenna connector.
Time to create page: 0.047 seconds
- Antenna for "recommended" NRF24L01 module (Devo 7e
