Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
12 Mar 2015 11:16 #29591 by Zaphod
I've setup Heli-x on my laptop and setup a model on the Devo 10 using USBHID. Aileron, elevator and rudder are all detected in Heli-x but throttle / collective only registers from centre stick down. Nothing registers from centre stick up.
I've run the calibration in Heli-x but still get the same result.
Any suggestions?
Title :)
12 Mar 2015 13:35 #29593 by linux-user
Replied by linux-user on topic Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
You are running MS-Windows?
Then maybe you need to calibrate something like "gamepad device" in device-manager before doing any calibration in HELI-X
13 Mar 2015 00:47 #29619 by Zaphod
Thanks for that. Found the calibration for the game controller but it registered exactly the same.
The model file in the tx was a direct copy of the Phoenix INI here. I've gone in and adjusted the throttle curves and now the collective registers correctly. Just need to adjust the rudder now as a slight move left registers as 100 instead of a gradual increase. Moving right does nothing at all.
13 Mar 2015 07:43 #29627 by linux-user
You may try these.
"heli-x-minimal" has only associated Ch1-ch4.
"heli-x" has additional:
FMOD1 -> ch5
FMOD2 -> ch6
RUD DR1 -> ch7 which I use for TH (=Autorotation in HELI-X)
Maybe this is not ideal, but it's working for me.
Throttle and pitch curves are configured inside HELI-X.
13 Mar 2015 17:47 #29655 by Zaphod
Thanks mate.I'll give them a try over the weekend and let you know how o go.
Cheers :)
16 Mar 2015 11:54 #29757 by Zaphod
OK gave the model files a go. Same result on the rudder - left rudder is 100% with the stick at 1%. Right rudder is 0 no matter its position.
No idea what's going on. The tx works fine on Phoenix and my helis. Just not on Heli-x.
16 Mar 2015 17:36 #29765 by linux-user
You have this "Deviation Gamepad" in device manager?
Are at least 4 channels working there?
Have you calibrated them in Windows before doing so in HELI-X?
16 Mar 2015 23:27 #29771 by Zaphod
Awwwww dammit. Did the Windows calibration of the Deviation Gamepad and it failed repeatedly on the rudder. Played a hunch and changed the USB cable and FMD it worked!!
Thanks so much for your help in getting this up and running! You're worth my weight in gold :)
Time to create page: 0.119 seconds
