complete deviation newbie needs help, bind fbl100
- sniper695
04 May 2015 13:48 #32061
by sniper695
complete deviation newbie needs help, bind fbl100 was created by sniper695
I soldered in the nrf board, enabled it in the text file. it seems to be working on the controller end. I have a brand new hisky fbl100 bnf. I can't get it to bind. I don't know if I am missing something. can someone explain the process I have been searching for an hour online and can't find much info. I'm really excited to fly my new heli.
so far I have selected the fbl80 model (that is the closet config I could find.) and tried to bind. nothing. I also tried to bind it as a new model, selected heli. hisky protocol, hit bind, restarted etc. I can't figure it out?
- Cereal_Killer
04 May 2015 15:11 #32066
by Cereal_Killer
Replied by Cereal_Killer on topic complete deviation newbie needs help, bind fbl100
Ok first the basics, the HiSky protocol doesn't have a "*" next to it does it?
What are you trying? Usually the process is setup the tx and have the cursor on the bind button, plug in heli, wait ~3 sec then hit bind. Please describe the process you're using.
- sniper695
04 May 2015 15:32 #32070
by sniper695
Replied by sniper695 on topic complete deviation newbie needs help, bind fbl100
no *
I tried battery, 3 seconds, hit bind nothing. is there anyway to check the module is soldered correctly?
I downloaded a fbl80 config that should be close enough right? I am pretty confused on the deviation software.
I can bind my super cp. if that gives any helpful info
- Cereal_Killer
04 May 2015 18:40 #32075
by Cereal_Killer
If there's no * and it doesn't give you an error message at power up its installed correctly.
Do you have the stock tx? These little toy grade models don't bind the same way say a spektrum RX does, they're very picky. I don't have a HiSky model any more and I don't remember exactly what it took.
Have you set a fixed ID or left it blank? Have you tried waiting longer / shorter? You've gotta get it just perfect.
- sniper695
05 May 2015 15:35 #32115
by sniper695
first time it had a fixed ID, I then tried it there after blank, I have tried it probably 20 times.
when I mounted the board it had a wire antenna, I cut it so it would fit in the devo 7e antenna slot, that is the correct way to do it right?
- Cereal_Killer
05 May 2015 16:08 #32119
by Cereal_Killer
What do you mean cut the antenna? You've got to have the antenna hooked up or you'll kill the module!
- sniper695
05 May 2015 17:28 #32127
by sniper695
the antenna cable, was like 6 inches long, as it was being removed from the plastic antenna it came with the person helping me cut it like 2 inches long, it is plugged into the chip. would that cause any issue?
- Cereal_Killer
05 May 2015 18:47 #32129
by Cereal_Killer
Absolutely, this may not be your ONLY issue but there's a good chance it is. Antenna are VERY PICKY and must be tuned exactly perfect, was it a single straight wire whip or a shielded wire with a dipole on the end?
Post a pic of your antenna and we can tell you if how you've cut it is ok or not.
- sniper695
06 May 2015 02:04 - 06 May 2015 12:09 #32138
by sniper695
This is what was cut off, the piece in the controller is about 2 inches long, can I just solder it back together if this is issue? How do I get this piece into antenna housing on devo7e
Last edit: 06 May 2015 12:09 by sniper695.
- sniper695
06 May 2015 12:10 - 06 May 2015 13:17 #32170
by sniper695
how do you add a picture? I added it 3 times, it does not show up
Last edit: 06 May 2015 13:17 by sniper695.
- sniper695
06 May 2015 13:27 #32171
by sniper695
the antenna has a small connector where it connects to board, similar to connector for wifi chip in a laptop, then about 6 inches of black wire, then a round metal piece about 3/16 round and 1 inch long. then about 1.5-2 inch piece of wire with clear plastic.
- Cereal_Killer
06 May 2015 14:35 #32172
by Cereal_Killer
Which end did you cut? Cutting the connector is ok, cutting the dipole is not.
sniper695 wrote: the antenna has a small connector where it connects to board, similar to connector for wifi chip in a laptop, then about 6 inches of black wire, then a round metal piece about 3/16 round and 1 inch long. then about 1.5-2 inch piece of wire with clear plastic.
- Deal57
06 May 2015 17:03 - 06 May 2015 17:04 #32182
by Deal57
Replied by Deal57 on topic complete deviation newbie needs help, bind fbl100
Did your board come with the antenna in this kit?
NRF24l01 @ Banggood
If so, you need to order another similar antenna. I have used COAXRF.com for quick service. Match up the connector on your board (which sounds like it is a u.fl) with the 2.4ghz antenna you need... You can call them for advice. Running the board without an antenna or with the wrong one may damage the board.
NRF24l01 @ Banggood
Last edit: 06 May 2015 17:04 by Deal57. Reason: fix URL
- Cereal_Killer
06 May 2015 19:23 #32185
by Cereal_Killer
Just to clarify, if you cut the connector off and soldered the cable (both the shield and the conductor) on to the board you'll be ok, if you cut the big thing off the end you've ruined it.
- sniper695
07 May 2015 11:43 #32206
by sniper695
It looks very similar to the antenna above, but it has no rubber on the thicker part (my has a 3/16 by inch long piece of metal), it is just metal, it came in a plastic antenna. The connector got cut off with about 2 inches of wire.
to make sure I understand, I need to take the piece of antenna that got cut off, and solder that to the connector on the board and it may be okay, if not I need to buy new board or antenna?
- Cereal_Killer
07 May 2015 12:27 #32207
by Cereal_Killer
Yea you've got it, the metal thing is the actual important part. It's the dipole part of the antenna. Try using it. You'll need to ensure polarity is correct, look at the piece with tunconnector still on it to see which part of the connector is the shield and which is the conductor and then try to determine the surface mounted plug's polarity so you can then remove the SMD plug, strip the insulation and solder directly to those pads.
- linux-user
07 May 2015 12:28 #32208
by linux-user
Replied by linux-user on topic complete deviation newbie needs help, bind fbl100
- sniper695
07 May 2015 23:58 #32234
by sniper695
If I want to make sure it works, am I better off just buying a new antenna? Or should I get the whole board antenna package?
Time to create page: 0.245 seconds
- complete deviation newbie needs help, bind fbl100
