Unable to locate hardware.ini file
- arkennedy75
15 Dec 2015 01:51 #40938
by arkennedy75
Unable to locate hardware.ini file was created by arkennedy75
I'm using Devation version 4.0.1 on Devo 7E. After navigating through all the folders on the 7E I'm unable to find the hardware.ini file. What am I missing?
- Deal57
15 Dec 2015 02:03 #40939
by Deal57
Replied by Deal57 on topic Unable to locate hardware.ini file
Hardware.ini was introduced after the release of 4.0.1. That release used the rx.ini file to set up the additional modules. Post-release the team decided to use a new hardware.ini file to manage hardware modifications. If you run the nightly builds you'll find the hardware.ini in the root folder of the USB drive, alongside tx.ini.
- arkennedy75
15 Dec 2015 02:08 #40940
by arkennedy75
Replied by arkennedy75 on topic Unable to locate hardware.ini file
Thanks for the response. I'm not seeing the rx.ini file either. Any suggestions?
- Deal57
15 Dec 2015 02:09 #40941
by Deal57
aw jeezz... That should have been TX.ini. There isn't any rx.ini. Sorry
- Unable to locate hardware.ini file
