Dev 7e Module mod gone bad
- Dante1
23 Jan 2016 18:17 #42129
by Dante1
Dev 7e Module mod gone bad was created by Dante1
Hello everyone,
I have a Devo 7e with the range mod. I tried to bind a DSM2 RX and no go. The LED constantly blinks as if it never communicated. I know it's not the ID because it would go through the bind process and then the LED would go off. I read somewhere that I can replace the module with a Devo 8 module. Is this correct? Where can I find one?
Thanks in advance.
Thanks in advance.
- anansi22
27 Jan 2016 16:40 #42274
by anansi22
Replied by anansi22 on topic Dev 7e Module mod gone bad
Banggood.com
- Dante1
27 Jan 2016 16:44 #42275
by Dante1
Replied by Dante1 on topic Dev 7e Module mod gone bad
Can you be a bit more specific? I searched Banggood and can't seem to find the part i need.anansi22 wrote: Banggood.com
- TomPeer
27 Jan 2016 18:22 #42280
Replied by FDR on topic Dev 7e Module mod gone bad
ehirobo has it in stock:
www.ehirobo.com/spare-parts/transmitters...-upgrade-module.html
- Dante1
27 Jan 2016 19:44 #42282
by Dante1
Do you know if I have to remove the old module and install the new one?
Yup, ordered it from there.FDR wrote: ehirobo has it in stock:
27 Jan 2016 19:58 #42284
Yes, you at least need to disconnect the old one, which is the same...
- Dante1
28 Jan 2016 12:38 #42312
by Dante1
Thanks. Hope it will bring my TX back to life.FDR wrote: Yes, you at least need to disconnect the old one, which is the same...
31 Jan 2016 16:29 #42465
I don't have a diagram, but the module installation guides for the Devo8 and 7e do contain assigned pins:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
- lahiru4216
08 Mar 2016 15:18 #44266
by lahiru4216
<<<<<<<<Fly Harder For More Fun>>>>>>>
Replied by lahiru4216 on topic Dev 7e Module mod gone bad
Here is the link for your module replacing
www.hacksmods.com/2014/10/wk-devo-s-mod-module-for-devo7e/
Time to create page: 0.159 seconds
- Dev 7e Module mod gone bad
