Devo 7E won't bind with RX2622V-D
- dpowellmeii@gmail.com
14 Mar 2016 07:24 #44546
by dpowellmeii@gmail.com
Devo 7E won't bind with RX2622V-D was created by dpowellmeii@gmail.com
Greetings,
I can't get my Devo 7E to bind with my RX2622V-D. I tried binding it when the tx was stock and no luck then I flashed the deviation software and still no luck. My 7E works fine with my super cp and blade nano cpx but so far not with this rx2622v-d. The rx is brand new and when I plug the battery up and try to bind it the light just flashes fast and doesn't do anything else.
Any ideas?
Thanks,
D
Any ideas?
Thanks,
D
- -=Hubi-Dirk=-
14 Mar 2016 17:13 #44567
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo 7E won't bind with RX2622V-D
Is there a Fixe ID stored? Remove it and try again.
15 Mar 2016 14:46 #44602
Replied by dpowellmeii@gmail.com on topic Devo 7E won't bind with RX2622V-D
This is what I ended up doing and it's working now, thanks.
The problem is the documentation on how to do this was hard to find, but I finally came across it. For anyone else having this issue here are some instructions to clear the fixed id.
- Leave the transmitter off to clear the fixed id on the rx
- Plug in the binding plug to the elevator port on the rx or short the two pins where the red and white servo wires plug into the elevator port.
- Plug up the battery and the led will start to flash slowly.
- The fixed id should now be cleared, unplug the batter and you are good to go.
Time to create page: 0.025 seconds
- Devo 7E won't bind with RX2622V-D
