Devo 10 A7105 install
30 Apr 2016 18:31 - 30 Apr 2016 18:31 #47501 by champstar2828
Devo 10 A7105 install was created by champstar2828
I'm only installing the a7105 module in my devo 10. My question is do I need to connect anything to TMS or MISO?
The diagram below shows theses connections only for another chip. Right now I did not connect them and I am getting the missing module message.
I will take it apart and check all connections. Any input will be appreciated.
Last edit: 30 Apr 2016 18:31 by champstar2828.
30 Apr 2016 18:51 #47502 by TomPeer
Replied by TomPeer on topic Devo 10 A7105 install
If you connected the csn to TCK then you do not need those 2 connections.
Make sure your hardware.ini looks like this:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A14
has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A13
; has_pa-nrf24l01 = 1
; enable-multimod = A13
30 Apr 2016 18:52 #47503 by champstar2828
Replied by champstar2828 on topic Devo 10 A7105 install
It does, I took the semi colons off of the 2 lines.
30 Apr 2016 18:53 #47504 by TomPeer
did you change A13 to A14
30 Apr 2016 18:59 #47505 by champstar2828
No I did not do that. Is that done in the hardware file?
30 Apr 2016 18:59 #47506 by champstar2828
I see it now
30 Apr 2016 20:01 #47510 by champstar2828
I re-connected everything and made the change. Now I'm getting missing module cyrf6936.
30 Apr 2016 20:28 #47513 by champstar2828
f..y.i, Im on latest nightly build, and using 22awg wire.
Time to create page: 0.060 seconds
