Devo 7e 3x2 switch mod, mixer problem?
18 May 2016 22:08 #48657 by lucas1414
Devo 7e 3x2 switch mod, mixer problem? was created by lucas1414
Hey everyone,
I 've just did the 2 x 3x2 switch mode on my devo 7e and everything works great, now I have swa 0,1,2 and swb 0,1,2 available as new switches. But how to make them act as a three way switch to command a channel. I only can choose one of the switch position from 0 to 2 and make it on or off. So the 3 way switch act as a 2 way. I have tried the complex mixer with multiple mixer on the same channel but I can't get it work. I can't find anything on internet
Someone how to make it work?
18 May 2016 23:09 - 18 May 2016 23:14 #48660 by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7e 3x2 switch mod, mixer problem?
Good news is you're almost there.
Complex mix
3 pages
Page 1
Switch is SWA0
Curve is fixed at 100
Page 2
Switch is SWA1
Curve is fixed at 0
Page 3
Switch is SWA2
Fixed at -100
Leave src as none (should force that when set curve type to fixed)
Last edit: 18 May 2016 23:14 by Cereal_Killer.
19 May 2016 02:15 #48669 by mwm
Replied by mwm on topic Devo 7e 3x2 switch mod, mixer problem?
As an alternative, you can do this with two pages:
page one: curve if fixed at 0, no switch.
page two: Src is SWA2, switch is !SWA1 (click the switch button to get the ! which inverts the test)., curve is min/max.
The three mixer version is more general, but figuring out how the above works is a good exercise for how to program deviation mixers.
19 May 2016 17:49 #48729 by lucas1414
Replied by lucas1414 on topic Devo 7e 3x2 switch mod, mixer problem?
All good! I wasn't thinking the right way, I start to get the way complex gui works. Do you have an example with mixer using add or mult for mux I don't understand where you can use it?
anyway thanks for the quick answers guys it helped a lot.
19 May 2016 18:27 #48730 by Cereal_Killer
I've ALWAYS done the 3-page mix method but I like MWM's 2-page method purely cause it's three less steps and you dont have the set the 0 and -100 points manually when setting it up in the GUI lol. I'm gonna be doing it that way from now on, thanks Mike!
20 May 2016 11:25 #48852 by mwm
I've used both add and mult in doing more than three flight modes for advanced flight controllers for other people. Because they are for other people, I don't have them at hand.
For example, tweak the three way so you're three values are -100, -20 and 60. Then use a 2 way switch as a source with scale of 20 and offset of 20 so it has values of 0 and 40. Use the add mix type for it, and you get the original values in one switch position, and -60, 20 and 100 in the other.
Alternatively, set up there 3 way as 20, 60 and 100, then use a 2 way as a source and multiply it. The 100% position gets the original values, the -100% position gets -20, -60 and -100.
Multiply is tricky because you are multiplying percentages, so a value of 50 in the multiply mixer will cut the incoming value in half. You can use this to get a "rate dial" if you have an extra analog input worth a multiply mixer.
Time to create page: 0.125 seconds
