Wrong .ini ...Yaw error
- ursus69
06 Jul 2016 18:58 - 06 Jul 2016 21:23 #51367
by ursus69
Wrong .ini ...Yaw error was created by ursus69
Hi!!
I'm building a diatone tyrant 215, with the F3 Acro 6DF and Orange V620X....and I have a strange problem..
I configured with cleanflight and my devo10 ...and the tyrant no YAW to right...and yaw to left perfectly...
My devo10 works well with my 200QX... and the controller tab in cleanflight seems ok..
I attach the .ini.....but I thinks it's ok..
What could be the problem??
Last edit: 06 Jul 2016 21:23 by ursus69.
- ursus69
06 Jul 2016 20:02 - 06 Jul 2016 20:17 #51369
by ursus69
I'm doing tests in cleanflight.... and when the quad is disarmed, the yaw works ok..
But when the quad is armed only have left yaw!!
I use the RUDD D/R (channel 10) to arm/disarm...and it's a simple mix....how affect to yaw (channel4)??
I see that the mixer in rudder is wrong....and when I use the rudd d/r blocks the right yaw...
How I would have to set the channel4 (yaw) mixer??
P.D....sorry for my bad english and bad deviation ini
Replied by ursus69 on topic No right Yaw
Last edit: 06 Jul 2016 20:17 by ursus69.
07 Jul 2016 01:59 #51378
Replied by mwm on topic Wrong .ini ...Yaw error
Delete the second mixer in that mix. That's what I'd blocking the yaw with dr.
If you want real dr on the rudder, try using an expo&dr mix instead of a complex mix.
- ursus69
07 Jul 2016 12:46 #51400
by ursus69
Replied by ursus69 on topic Wrong .ini ...Yaw error
Perfect! Thanks mwm!!
- Wrong .ini ...Yaw error
