DIY-FRSKY-8CH Devo 10 help
06 Aug 2016 11:34 #52492 by DJDavid33
Replied by DJDavid33 on topic DIY-FRSKY-8CH Devo 10 help
I need to connect the pin 5 of the rx however naze32 (rev5)?
and what order I have to type in the CLI
thank you
06 Aug 2016 13:08 - 06 Aug 2016 13:12 #52498 by aMax
Replied by aMax on topic DIY-FRSKY-8CH Devo 10 help
1.
Look at the manual.....which pin it is on the Naze32.. :whistle:
2.
set sbus_inversion = OFF
Last edit: 06 Aug 2016 13:12 by aMax.
06 Aug 2016 20:55 #52507 by aMax
Made an update on post
www.deviationtx.com/forum/6-general-disc...h-devo-10-help#52481
Sorry, dude, got a little confused finally. :woohoo:
07 Aug 2016 15:09 #52544 by DJDavid33
I could not try it because I reversed the vbat and my naze32 no longer works I expect to receive the new
thank you again for your help
07 Aug 2016 22:53 #52559 by aMax
Did you remove the shrink tube from the rx? There is a new board layout, so no need for soldering on the Atmel anymore.
Pads for Sbus and telemetry are already there.
static.rcgroups.net/forums/attachments/1..._0027-cut-small7.JPG
08 Aug 2016 11:31 #52575 by DJDavid33
hello mine is different I have to weld for the SBus
08 Aug 2016 16:57 #52589 by aMax
OK.
Old board; new sticker.....in the meantime they have been sending this little rx even with a small case.
To get this project running, I would advise to keep it simple and go with PPM first
This will free uart2 for something else, e.g. bluetooth. Later on, if all is working as expected, you can switch to sbus......if necessary.
18 Aug 2016 21:01 - 18 Aug 2016 21:04 #52884 by DJDavid33
hello it finally works with a new RX the other had a defect.
I flashed with the latest version "FrskyRx_F802_130816.hex"
this is the one for the F802 rx but it works for the F801.
My problem is that I have the signal failure in flight. Yet I have great worn. the signal works intermittently.
I do not know or just the problem.
or the flash with another version or another thank you.
Last edit: 18 Aug 2016 21:04 by DJDavid33.
Time to create page: 0.212 seconds
