hardware.ini
- Podflyer
17 Aug 2016 19:43 #52846
by Podflyer
hardware.ini was created by Podflyer
I have done the 3 in 1 mod to my devo 10 but none of the models will bind when i go to select a protocol such as syma there are no options to chose the different models as there was on my moded devo 7e I just get a reinialise option rather than bind now as well. I think it's an issue with my .ini file I tried removing the ; but then got a missing modules error. see below if any one could send me a correct .ini file for v5.0 that would be great
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 | = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
; has_pa-cc2500 = 1
- D_an_W
17 Aug 2016 20:26 #52848
by D_an_W
Replied by D_an_W on topic hardware.ini
This is mine, I have the 4-in-1 installed.
You will have to edit the location to match where you soldered in the wiring for the module selectors.
;enable-haptic=1
;extra-switches=
extra-buttons=trim-all
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A14
has_pa-a7105 = 1
enable-cc2500 = A13
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13*** Walkera Devo 10 * 4-in-1 Module * Deviation v5 *** *** Walkera Devo 7E * A7105 Module * 2x 3 Way Switches * Power Mod * Deviation v5 ***
- Podflyer
17 Aug 2016 21:27 #52850
by Podflyer
Replied by Podflyer on topic hardware.ini
This is the module i installed and the wiring diagram will your .ini work with this?
www.banggood.com/CC2500-NRF24L01-A7105-M...itter-p-1046304.html
- D_an_W
18 Aug 2016 05:16 #52862
by D_an_W
Assuming you wired it the same as on that page I think you need the following but I am no expert at this so just give it a go!
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- Podflyer
18 Aug 2016 07:34 #52863
by Podflyer
Thanks will try tonight.
- Podflyer
18 Aug 2016 18:48 #52880
by Podflyer
So now I just get missing modules message when i switch the Tx on. I have tried isolating each module with a semicolon in case I wired one wrong but that didn't help. the line has_pa-a7105 | = 1 confuses me should the"|" be there? if any one can help that would be great as I'm on the verge of giving up flying. the file i'm using is below
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 | = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 | = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- D_an_W
18 Aug 2016 20:24 #52883
by D_an_W
I don't have a | there, did you copy and paste what I posted?
What file editor are you using as I think Notepad can mess things up, I use WordPad.
- Podflyer
19 Aug 2016 09:03 #52893
by Podflyer
Yep tried what you posted same error (missing modules) then added the | as this is on the example at bangood and got the same error too. Any one else had similar issues?
- bazsound
19 Aug 2016 10:44 #52894
by bazsound
Replied by bazsound on topic hardware.ini
www.deviationtx.com/forum/7-development/...4in1-rf-module#43726
shows what you need in your hardware ini. it should just be a case of removing the ; before each module and has pa.
note you cannot use notepad, i accidentally did this and had issues. You need to use notepad ++
I ended up having to reflash the firmwar and copy over the filesystem (not sure if reflashing was nessesary but copying over just a fresh hardware.ini didnt work)
I had the missing module problem, it went way but the module didnt work (acted like the module wasnt there * beside protocls means no module)
Use Notepad++ to edit hardware ini and do file save.
- Podflyer
19 Aug 2016 14:05 #52901
by Podflyer
Thanks will try that next.
Time to create page: 0.117 seconds
- hardware.ini
