Devo 10 w/4in1 module
04 Jan 2017 04:55 #57523 by Boomer45
Devo 10 w/4in1 module was created by Boomer45
I just installed BG 4in1 module and downloaded deviation s/w, now I get "missing modules multimod OK"
Any ideas as to what happened?
Ron
04 Jan 2017 05:53 #57526 by ajtank
Replied by ajtank on topic Devo 10 w/4in1 module
Did you remove the semi-colon on the last line: enable-multimod = A13?
Put the semi-colon back.
04 Jan 2017 17:51 #57534 by Boomer45
Replied by Boomer45 on topic Devo 10 w/4in1 module
Thanks ajtank, but no change. Other ideas?
04 Jan 2017 20:41 - 04 Jan 2017 20:43 #57535 by Arnold
Replied by Arnold on topic Devo 10 w/4in1 module
Boomer45 wrote: Thanks ajtank, but no change. Other ideas?
Maybe you failed to save the hardware.ini file after putting the ";" back.
Or...
Maybe you didn't put the revised hardware.ini file with the ";" back in the Devo.
I doubt that you could have a version of Deviation that searches for the Multimodule on its own.
That's all I can think of. :)
Last edit: 04 Jan 2017 20:43 by Arnold.
04 Jan 2017 23:22 #57542 by hexfet
Replied by hexfet on topic Devo 10 w/4in1 module
Post your hardware.ini and a pic of your installation.
Time to create page: 0.177 seconds
