MJX X601H
05 Sep 2018 01:26 #70649 by rond
MJX X601H was created by rond
New member with a problem unlocking the motors on the X601H. I have the Jumper T8SG Plus and it binds but I can not unlock the motors. Does anyone know what channel I should be looking at? Thanks
05 Sep 2018 01:30 #70650 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic MJX X601H
Maybe this can help,
05 Sep 2018 01:31 #70651 by C0ckpitvue 777
Video by frequent flyer rc.
05 Sep 2018 13:19 #70660 by rond
Replied by rond on topic MJX X601H
thanks for the reply
I have tried this and it binds but the motors won't start
05 Sep 2018 16:07 - 05 Sep 2018 22:57 #70664 by hexfet
Replied by hexfet on topic MJX X601H
<info removed> This post had bugs3 information. See below for MJXq.
Last edit: 05 Sep 2018 22:57 by hexfet.
05 Sep 2018 17:44 - 05 Sep 2018 18:52 #70666 by C0ckpitvue 777
Which switch is channel 10 on the devo10?
Last edit: 05 Sep 2018 18:52 by C0ckpitvue 777.
05 Sep 2018 22:06 #70669 by propnut
Replied by propnut on topic MJX X601H
Whatever switch you want it to be. It is fully customisable. Set it up under mixes.
05 Sep 2018 22:45 #70670 by rond
Thanks but channel 5 appears to control the lights on and off on this model
05 Sep 2018 22:57 - 05 Sep 2018 23:02 #70671 by hexfet
Sorry I had the wrong protocol. Skipped through the video too fast. Edited the previous post.
The channel information is in the user manual (copied below). Maybe try selecting H26HW format. Or perhaps the X601H has a slightly different protocol. Is there a separate "motor on" button or switch on the stock transmitter?
The MJXq protocol supports 12 channels and only supports auto-binding.
The first four channels are Aileron, Elevator, Throttle and Rudder.
Channel 5 controls LEDs, or arm if H26WH format is selected.
Channel 6 controls Flip mode.
Channel 7 controls the still camera
Channel 8 controls the video camera.
Channel 9 controls headless mode.
Channel 10 controls RTH mode
Channel 11 controls autoflip (X600 & X800 formats) or camera pan
Channel 12 controls camera tilt
Last edit: 05 Sep 2018 23:02 by hexfet.
06 Sep 2018 11:43 #70685 by rond
Thanks again, I will try H26WH
yes there is an unlock button on the stock transmitter
07 Sep 2018 15:50 #70726 by rond
okay that doesn't work
there must be some way to turn on the motors
12 Sep 2018 19:46 #70853 by hexfet
Maybe not if the protocol is different. Would need SPI captures from the stock transmitter to be sure.
Have you tried all the channels in the protocol? Maybe one is used for arming in this model.
13 Sep 2018 01:36 #70863 by rond
yes I did try all the channels with no luck
I am going to try and download the bugs 3 software and see if it will work
07 Nov 2018 15:00 #71612 by rond
Still no luck with this model, have had so much rain lately I haven't messed with the drones
07 Nov 2018 16:16 - 07 Nov 2018 23:54 #71614 by goebish
Replied by goebish on topic MJX X601H
I suppose the X600H requires an extra flag to start motors compared to the X600.
I'll make a test build later where you can control individual bits manually, we may be able to find it like that if you do not have a logic analyzer.
Also try to set both sticks in the bottom corners, some quads can start motors like that.
Last edit: 07 Nov 2018 23:54 by goebish.
09 Nov 2018 20:02 #71684 by rond
Thanks, I will try that. I have ordered an analyzer but who knows if or when it will get here.
Time to create page: 0.092 seconds
