Controlling Devo 7E transmitter from a PC
21 Oct 2018 13:37 - 21 Oct 2018 13:38 #71447 by roineust
i'm trying to control my Devo 7E via my PC using an Arduino, the following software and instructions:
www.min.at/prinz/?x=entry:entry130721-182227
The problem i have is this: The Devo joystick throttle, controls the servo i'v connected to the receiver, but when trying to control the servo via the PC software, the servo moves a little bit after a delay and then the Devo goes into restart.
Can anyone help me here?
Last edit: 21 Oct 2018 13:38 by roineust.
21 Oct 2018 19:50 #71451 by hexfet
Replied by hexfet on topic Controlling Devo 7E transmitter from a PC
Are you using the stock firmware or deviation? If deviation, what version? If not deviation, upgrade to deviation and we can help :)
22 Oct 2018 09:59 #71462 by roineust
Replied by roineust on topic Controlling Devo 7E transmitter from a PC
i'm using devo7e-v4.01
22 Oct 2018 19:20 #71471 by hexfet
That's a very old version. Recommend installing the latest nightly build.
That said, the PPM input code hasn't changed in a long time. Never heard of any PPM input causing a reset, so recommend double-checking the signal and ground connections to the trainer port. Do you have any way of checking what the PPM signal from the arduino looks like?
Time to create page: 0.314 seconds
